Chat freely about anything...
By Sirquil
#91751 I select a filename from a list that calls a function to read a plain text file. I would like to add a url link to return to the list of filenames
This standalone html code for win pc does what i am trying to accomplish using Asyncwebserver:
Code: Select all[<html>
<head>
<title>README</title>
</head>
<body>
<div><object data="C:\users\1234\Desktop\Notes\LOG07042020.TXT" width="100%" height="800"></object></div>
<br><h2><a href=http://10.0.0.100:8030/Weather >Home</a>
</body>
</html>
instead of "C:\users\1234\Desktop\Notes\LOG07042020.TXT" I would like to use a variable.
My attemps using code from Asyncwebserver documentation for sending html code have all failed.
Mt latest attempt:
Code: Select all        String resp = "<!DOCTYPE html><html><head><title>Observations</title></head><body>";
        resp += "<div><object data" + fn + " width='100%' height='800'></object></div>";
        resp += "<br><h2><a href=http://10.0.0.100:8030/SdBrowse >SdBrowse</a></body></html>";
        AsyncWebServerResponse *response = request->beginResponse(200, "text/html", resp);
        response->addHeader("Access-Control-Allow-Origin","*");
        request->send(response);
Compiles; does add urllink; however, plain text log file is not displayed. An example for fn would be "/LOG06142021.TXT." Have tried inserting filename; still no text display.
William
By Sirquil
#91758 zekageri provided this code for an issue on the Asyncwebserver website; thank you zekageri.
Code: Select all serverAsync.on("/Observations", HTTP_GET, [](AsyncWebServerRequest *request){
         resp += "<div><object data=/LOG06132021.TXT width='100%' height='800'></object></div>";
         resp += "<br><h2><a href=http://10.0.0.100:8030/Weather >Home</a></body></html>";
Can this code be modified to work from this function? Replacing "request->send(SPIFFS, fn, String(), false); //Display file."
Code: Select allvoid notFound(AsyncWebServerRequest *request)
  digitalWrite(online, HIGH);   //turn-on online LED indicator
  if (! request->url().endsWith(F(".TXT")))
    request->send(404);
  else
    if (request->url().endsWith(F(".TXT")))
      //.endsWith(F(".txt")))
      // here comes some mambo-jambo to extract the filename from request->url()
      int fnsstart = request->url().lastIndexOf('/');
      fn = request->url().substring(fnsstart);
      PATH = fn;
      accessLog();
      Serial.print("File:  ");
      Serial.println(fn);
      File webFile = SPIFFS.open(fn);
      Serial.print("File size: ");
      Serial.println(webFile.size());
      if (!webFile)
        Serial.println("File:  " + fn + " failed to open");
        Serial.println("\n");
      else if (webFile.size() == 0)
        webFile.close();
      else
        //request->send(SPIFFS, fn, String(), true);  //Download file
        webFile.close();
      fn = "";
      end();
  digitalWrite(online, LOW);   //turn-off online LED indicator
Pablo2048 provided the function code for an issue on the Asyncwebserver website; thank you Pablo2048.
William
(1.16 KiB) Downloaded 147 times
By Sirquil
#91873 Have a solution to request using "JavaScript"; provided, in an example by Sara Santos of "RNTlab.com."
Solution code I am using to add header, text area, and hyperlink to an all text file:
"HTML6":
```//index6.h
const char HTML6[] PROGMEM = R"====(
<!DOCTYPE HTML>
<html>
<head>
    <title>Show</title>
    <meta name="viewport" content="width=device-width, initial-scale=1">
<style>
.main
  type: text/txt;
  font-size:18px;
  width: auto;
  height: auto;
  margin: 30px;
</style>
</head>
<body>
    <h2>Observations
    <!-- <a href="/Show"><button>Show Log File</button></a> -->
    <br>
    <br>
    <div class="main" style="white-space: pre-wrap;" type="text/txt" id=file-content></div>
    <!-- <p style="white-space: pre-wrap;"id="file-content"></p>  -->
    <br>
    <a href=http://%LINK%/SdBrowse >SdBrowse</a></h2><br>
</body>
<script>  //JavaScript by Sara Santos
  window.addEventListener('load', getFile);
  function getFile(){
    var xhr = new XMLHttpRequest();
    xhr.onreadystatechange = function()
      if (this.readyState == 4 && this.status == 200)
        console.log(this.responseText);
        document.getElementById("file-content").innerHTML=this.responseText;
  xhr.open("GET", "/get-file", true);
  xhr.send();
</script>
</html>
Request "/Show " //Loads HTML6
  serverAsync.on("/Show", HTTP_GET, [](AsyncWebServerRequest * request)
    PATH = "/Show";
    accessLog();
    if (! flag == 1)
      request->send_P(200, PSTR("text/html"), HTML6, processor6);
    end();
Request to get text file for HTML6:
 serverAsync.on("/get-file", HTTP_GET, [](AsyncWebServerRequest *request){
  request->send(SPIFFS, fn, "text/txt");
Request to get redirect from "notFound" function:
 serverAsync.on("/redirect/internal", HTTP_GET, [](AsyncWebServerRequest *request){
    request->redirect("/Show");  //recevies HTML request to redirect
ESP32 Project website
ESP32 Project "RainGauge" code
William
