By john77
#92543 I see all prints outside like
Code: Select allSerial.println("UDP OK");
Now I want to receive a char from a terminal
Code: Select allvoid UART_Get()
     char chr;
    if (Serial.available() > 0)
        chr = Serial.read();
        //for debug
        Serial.print(chr);
and I put it in a loop
Code: Select allvoid loop()
     UART_Get();
But I get nothing.
I test the RX pin with a scope and I see incoming signals on the pin.
What can be wrong?
By prgvitor
#92546
john77 wrote:I see all prints outside like
     char chr;
        //for debug
        Serial.print(chr);
     UART_Get();
But I get nothing.
What can be wrong?
Check the baudRate value in "Serial.begin(value);" in "void setup()". The value must be the same as configured with another device. For ESP8266 the values ​​can be 115200 or 78880, try changing the baudRate.
Also check the RX (Arduino) -> TX (Modulo), TX (Arduino) -> RX (Modulo) connections.
You can also concatenate characters into a String:
String dataRec = "";
void UART_Get()
char chr;
dataRec.concat(chr);
Serial.print(dataRec);
