Chat about current Lua tools and IDEs
By hobby_guy
#93474 Thanks for the response :)
I installed esptool.py and PyFlasher GUI, and was able to install the NodeMCU variant I built at https://nodemcu-build.com Since I don't believe I have any very special needs, I went with the default modules included:
file, GPIO, net, node, timer, UART, WiFi
After flashing the BIN file to the ESP8266 successfully (with GPIO0 pulled low), I restarted the ESP and opened ESPlorer. However, ESPlorer still doesn't seem to be able to interface with the ESP. I seem to be getting very similar problems as I had earlier, when the ESP was running the "default" AT firmware.
First, I select COM7 and 115200 in the right pane, and click OPEN. This outputs:
Code: Select allPORT OPEN 115200
Communication with MCU...
and
Code: Select allLogging enable
LAFcom.sun.java.swing.plaf.windows.WindowsLookAndFeel
LAFcom.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel
LAFcom.sun.java.swing.plaf.motif.MotifLookAndFeel
LAFjavax.swing.plaf.nimbus.NimbusLookAndFeel
LAFjavax.swing.plaf.metal.MetalLookAndFeel
Load saved settings: Firmware:NodeMCU
Snippets: loading...
Snippets load: Success.
Set new color theme: Success.
Load saved settings: DONE.
Scan system...
found last saved serial port COM7
Scan done.
Serial port COM7 save as default.
Baud rate 115200 save as default.
Try to open port COM7, baud 115200, 8N1
Open port COM7 - Success.
sending:<CR><LF>
When I load my init.lua in the Editor (left pane) and click "Upload", I get the following output:
Code: Select allTry to open file init.lua
File name: C:\ESP8266 web server\init.lua
Try to load file init.lua
Loading init.lua: Success.
Open "init.lua": Success.
Uploader: Communication with MCU not yet established.
By hobby_guy
#93475 When booting the ESP without GPIO0 grounded, I get a bunch of noise in a terminal program (at 115200 baud). However, I found this very interesting website explaining that these initial bytes are not random noise at all, but some OS output -- which is coming at 74880 baud:
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 27444, room 16
tail 4
chksum 0xef
load 0x00000000, len 0, room 4
tail 0
chksum 0xef
ho 12 tail 0 room 4
load 0x00000000, len 0, room 12
tail 0
chksum 0xef
csum 0xef
csum err
ets_main.c
By quackmore
#93476 something went wrong while flashing the firmware
that's why you get "csum err"
now the firmware cannot boot properly and ESPlorer cannot connect
erase the flash and try again
here's some troubleshooting docs for esptool.py https://docs.espressif.com/projects/esptool/en/latest/esp8266/troubleshooting.html
if you're not sure about your new binary you might wanna try erasing and flashing the AT firmware
https://docs.espressif.com/projects/esp-at/en/release-v2.2.0.0_esp8266/AT_Binary_Lists/ESP8266_AT_binaries.html
