I am testing the board of: ESP8266 OLED VENDOR WIFI
what board should pick on Arduino 1.8.16?
Thanks
Adam
[img]
https://ibb.co/56ZwnjF
[/img]
Explore... Chat... Share...
I have used some WEMOS D1 mini pro clones where th[…]
Right at the beginning of the Exception Decoder ou[…]
GPIO15 is the Tx pin. So it is an output once you […]
This is basically a bootloader error: https://stac[…]
Does the error occur no matter what you try to upl[…]
From what you have said you have uncommented the l[…]
Here are some points about this error occurring wi[…]
Here is a power supply design for ESP8266. https[…]
WiFi.persistent(false); WiFi.mode(WIFI_ST[…]
You have to chose 'NodeMCU 1.0 (ESP-12E module)'.
Hi, what is the compiler that you're using and ge[…]
What if I simply call WiFi.begin("myssid"[…]
Follow US on Twitter and get ESP8266 news and updates first.
