If your sketch does not run, then the boot messages will give an error code.
Explore... Chat... Share...
bra1n wrote:Is the baud rate in your serial monitor set to 115200 (I suspect not)
rooppoorali wrote:As the previous answerer said, this type of garbage value appears in the serial monitor due to a baud rate mismatch. Kindly check that.
AcmeUK wrote:If you are getting gibberish whenever you push the button on the controller, THEN that will be messages from the boot ROM a 74880 baud.I don't see an option for a 74880 baud in the list?
Hi @QuickFix Thank you for your response. I am fin[…]
This is for Compiler Chat! Not sure, but TS co[…]
I noticed that my browser would not load completel[…]
This is a Google Script that retrieves environment[…]
Thanks for sharing. I did something similar a few […]
You can use Raspberry pi instead. You can run a py[…]
https://arduino.stackexchange.com/questions/43213/[…]
It seems like there are a few issues with your cod[…]
There could be a number of reasons why this is hap[…]
The code you installed was likely meant for the ES[…]
Yes, there are examples of connecting to an ESP826[…]
Using an ESP8266 to read the duty cycle of the sea[…]
Positioning the ESP-32 on top to dissipate heat is[…]
It sounds like the two Sonoff Basic devices you ar[…]
Some similar problems have been discussed in the f[…]
Follow US on Twitter and get ESP8266 news and updates first.
