This is work OK. conn:connect(7777,"192.168.1.255")
Explore... Chat... Share...
import socket
UDP_IP = "0.0.0.0"
UDP_PORT = 15000
sock = socket.socket(socket.AF_INET, # Internet
socket.SOCK_DGRAM) # UDP
sock.bind((UDP_IP, UDP_PORT))
while True:
data, addr = sock.recvfrom(1024) # buffer size is 1024 bytes
print("received message:", data)
