I want to run 2 server on different port. Is it possible for me ?
I am using :-
AT version:0.21.0.0
SDK version:0.9.5
One will be UDP server and other will be TCP or both server will be on TCP will be fine for me.
Please help me for this
Explore... Chat... Share...
martinayotte wrote:No the problem is about number of cores ...
ArduinoESP can support multiple TCP servers on different ports, for example HTTP on 80 and Telnet on 23.
The ESP8266WiFi can handle that easily in with proper code loop().
The problem is that @SanjaSameer wish to do that with AT firmware ...
I doubt that this crappy AT firmware could handle that since any second AT+CIPSERVER will replace the first one, there is no concept of array of servers.
