Moderator: Mmiscool
I reflashed the nodeMCU with the 1M build and the load program worked flawlessly!
I have no idea why BUT it fixed the immediate problem HOWEVER when running ESP Basic in 1M build mode, there is no "DEBUG" facility which I use systematically
Does this snippet of information help anyone to determine the root cause of the problem?
Cheers
Barry
VK2XBP
robert badiduwitz wrote:This may or may not help, but worth a shot. Whenever I had really unexpected reboots, crashes, etc., a good amount of times it was power related. It might be worth it just to check your supply and what usually worked for me was adding a 470uf or so larger cap and a smaller like .1uf cap close to the power pins. It surprised me many times that this fixed so many of my reboot and crash problems. Just a thought...
Hi Robert,
Thanks for your suggestion. I made the appropriate mods across the +5V (Vin) and GND pins on the nodeMCU but it made no difference. As a power source, I have used the USB output from my laptop, a USB charger and a bench power supply - all to no avail
Cheers
Barry
VK2XBP
The simple way of finding out which, is to reflash with 4Mb again.
If it still misbehaves on a fresh 4Mb then you're running out of memory, so you're going to have to somehow reduce memory usage (eg: reduce branch and var names to minimal abbreviations) if you want to be able to use debug on 4Mb.
