Doing as NickLD posted:
This is my Favorite method of serving any webpage content from an ESP that's more complex than a few lines:
1. Create a new file in the Arduino IDE named index.h
2. Put this inside it:
CODE: SELECT ALL
const char MAIN_page[] PROGMEM = R"=====(
/// Your entire webpage here. (Can be multi-line)
3. Make sure you save it, and import it in your main sketch file:
CODE: SELECT ALL
#import "index.h"
4. Now to serve the web-page, simply do this:
CODE: SELECT ALL
httpServer.send(200, "text/html", MAIN_page);
Plus adding Pablo2048 small correction:
Yes, exactly, what NickLD wrote with small correction:
replace httpServer.send(200, "text/html", MAIN_page); with httpServer.send_P(200, "text/html", MAIN_page, sizeof(MAIN_page));
there are _P methods for direct PROGMEM output (see ESP8266WebServer.h)
My "index.h" file:
//index.h
getWeatherData();
if(!isnan(dew))
gpslat = gps.location.lat();
gpslng = gps.location.lng();
gpsalt = gps.altitude.feet();
// First send the success response code.
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: html");
client.println("Connnection: close");
client.println("Server: Robotdyn WiFi D1 R2");
// Send an empty line to signal start of body.
client.println("");
// Now send the response data.
// output dynamic webpage
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head><title>Weather Observations</title>");
client.println("<body>");
// add a meta refresh tag, so the browser pulls again every 15 seconds:
// client.println("<meta http-equiv=\"refresh\" content=\"15\">");
client.println("<h2>Rain Gauge Two<br>");
client.println("Indianapolis, Indiana</h2></head><br>");
if(lastUpdate != NULL)
client.println("Last Update: ");
client.println(lastUpdate);
client.println(" <br>");
client.println("Latitude : " );
client.print(gpslat,5);
client.print(" <br>");
client.println("Longitude : " );
client.print(gpslng,5);
client.println("Elevation");
client.print(gpsalt,0);
client.print(" Feet.<br>");
client.println("Temperature: ");
client.print(temp, 1);
client.print(" C.<br>");
client.println("Humidity: ");
client.print(hum, 1);
client.print(" %<br>");
// client.println("Dew point: ");
// client.print(DewPoint, 1);
// client.print(" F. <br>");
// client.println("Heat Index: ");
// client.print(HeatIndex, 1);
client.println("Barometric Pressure: ");
client.print(pressure, 1); //Inches of Mercury
client.print(" hpa.<br>");
client.println("Rain Day : ");
client.print(rainDay, 2); //Inches of Mercury
client.print(" Day/mm <br>");
client.println("Rain Hour: ");
client.println(rainHour, 2); //Convert hPA to millbars
client.println(" Hour/mm <br>");
client.println("Rain5min : ");
client.print(rainFall, 2);
client.print(" Five min/mm <br>");
// client.println("Elevation: 824 Feet<br>");
client.println("<h2>Weather Observations</h2>");
client.println("<h3>" + dtStamp + " </h3><br>");
client.println("<br>");
client.println("<a href=http://" + publicIP + ":" + LISTEN_PORT + "/SdBrowse >File Browser</a><br>");
client.println("<a href=http://" + publicIP + ":" + LISTEN_PORT + "/Graphs >Graphed Weather Observations</a><br>");
client.println("<a href=http://" + publicIP + ":" + LISTEN_PORT + "/README.TXT download>Server: README</a><br>");
client.println("<a href=https://forum.arduino.cc/index.php?topic=606947.0>Project Discussion</a><br>");
//Show IP Adress on client screen
client.print("Client IP: ");
client.print( remoteIP().toString().c_str());
client.println("</body>");
client.println("</html>");
I have #import "index.h" in main part of the code.
Asyncwebserver object:
AsyncWebServer serverAsync(8080);
Attempt to send:
serverAsync.on("/Weather", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "text/html", MAIN_page, sizeof(MAIN_page));
Compiling produces error:
invalid conversion from 'const char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
How can multiple line HTML be sent using Async Web Server?
William
