check the state of gpio0/2; both should be high for executing user code on the esp.
Explore... Chat... Share...
The system doesn't like 74880.
The code you have are for Atmel microprocessors an[…]
I am also having issues with timers in ESP. I use[…]
OK, It's about 2 years ago, I've posted here about[…]
I run the Espressif supplied tools on the files to[…]
Since anything you ever want is on the Internet, I[…]
Once the command prompt’s black window appears, ty[…]
hi, tochange the interval I told you to change th[…]
I have a project ( A PID temperature controller) t[…]
https://www.esp8266.com/viewtopic.php?p=73027#p730[…]
so which compiler do you use? ... ;-) Apart from[…]
Hi, I didn't go through with the examples which Ma[…]
Follow US on Twitter and get ESP8266 news and updates first.
