By coreywi
#86158 I'm testing updating the firmware on a couple of -01 board. Every time I flash I always end up with an unusable board. After the flash, I hook up the Arduino Serial Monitor, RESET the board, and it only responds with something like this:
Code: Select all18:10:36.290 ->  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
18:10:36.290 ->
18:10:36.290 -> load 0x40100000, len 2592, room 16
18:10:36.290 -> tail 0
18:10:36.290 -> chksum 0xef
18:10:36.290 -> load 0x00000000, len 0, room 8
18:10:36.290 -> load 0x00000000, len 0, room 0
18:10:36.290 -> csum 0xef
18:10:36.290 -> csum err
18:10:36.290 -> ets_main.c
On 74880 baud, no less. I'm assuming this is a crash.
There appears to be dozens of resources on the internet, all with different instructions and with different firmware .bin file load addresses. Compounded with different firmware sets, NonOS, etc., I obviously haven't got the right mix of parameters to reflash.
All I know from the board is that what the Detected Info tells me:
flash vendor:
5Eh : N/A
flash devID:
4014h
QUAD;8Mbit
crystal:
26 Mhz
Can anyone point to a definitive resource that I can use to bring these clobbered boards back to a factory state? i.e. responds to AT commends?
Thanks!
