Chat here about code rewrites, mods, etc... with respect to the github project https://github.com/esp8266/Arduino
By Nico van der Dussen
#22756 Hi,
I'm a newbie to ESP8266 and just loaded my first sketches :)
I have a ESP12 module, using an CP2102 programmer and an external 3.3V powersource.
I'm using Arduino IDE 1.6.5r2 on Windows 8.1 and am trying to get the ESP8266 to communicate with the serial monitor.
I tried to load the example connect to wifi sketch, but did not see anything on the serial monitor :(
I reduced the sketch to
Code: Select allvoid setup() {
Serial.print(".");
And stil can's see anything on the serial monitor.
I experienced the following:
If the serial monitor is open while trying to upload, the upload fails.
My process is to close all IDE windows except the one I want to upload, upload and then open the monitor.
Up to now I was not able to see anything in the monitor.
Please assist :)
#22758 Ok,
Just after posting I noticed that my code was lacking a setup
changed to
Serial.print("X");
It did not solve the problem - still nothing happens in the Monitor screen
By Lotus
#23362 If you have the RST and GPIO0 pins connected to RTS and DTR I noticed the Arduino Serial Monitor pulls those two lines low preventing the esp8266 from running. You can use another terminal emulator or disconnect those lines.
