I don't know what the problem is but if we do not create WiFiClient for every request just like the example doing, then we can not get continues response from the TCP Server.
for example:
const char* ssid = "team";
const char* password = "team";
const char* host = "192.168.31.113";
WiFiClient client;
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.println("");
int value = 0;
delay(1000);
++value;
if (!client.connected()){
Serial.println(host);
const int httpPort = 1234;
return;
//client.write("\xFE\xEF\x0E\xE2\x06\xDB\x48\xB4\xB0\x04\x00\xA2\x00\x04\x16\x1C\xB4",17);
client.write("hello\r\n");
client.flush();
while(client.available()){
//String line = client.readStringUntil('\r');
Serial.print(client.read(),HEX);
Serial.print(" ");
if we use other program like python, everything responses well,so server side should be ok, but if we change to ESP 12-E board as TCP client, and use the code above, the response come randomly. it seem the 80% response has been lost, mean while the server side gives all the response successfully return.
what can be the problem?
thanks.
