By koty0f
#34551 Hi. I was searching here about max speed of esp. Someone sais about 1Mb/s someone few Kb/s. Can anyone tell me how it is with speed? I want to make bridge between uart and wifi and send packets. UDP can be but TCP will be better. I tried with some lua scripts but i could do only few Kb/s.
Which SDK should I use? The new arduino IDE? Thanks!
By mrburnette
#34560
koty0f wrote:Hi. I was searching here about max speed of esp. Someone sais about 1Mb/s someone few Kb/s. Can anyone tell me how it is with speed? I want to make bridge between uart and wifi and send packets. UDP can be but TCP will be better. I tried with some lua scripts but i could do only few Kb/s.
Maybe: http://www.esp8266.com/viewtopic.php?f=19&t=1250
or
http://www.esp8266.com/viewtopic.php?f=29&t=5578
By FrancoLP
#48059 Hello,
I write to ask about the maximum speed of transmission and reception reaching the ESP8266 in stream mode.
I need to transmit at a speed of 1Mbps but in several forums I've found that the ESP8266 not reach that number.
It is possible to configure it so that you reach that speed?
From already thank you very much!
Regards,
Franco La Paz
