esp8266-test-boards [2015/10/23 10:49] drum [Olimex ESP8266-EVB EValuation Board] |
esp8266-test-boards [2016/06/16 15:55] livetelevision [AI-Thinker 'Test Board'] |
Line 18: | Line 18: | ||
==== AI-Thinker 'Test Board' ==== | ==== AI-Thinker 'Test Board' ==== | ||
- | The AI-Thinker board is an evaluation board with an onboard STC15L204EA microcontroller along with a relay, buttons and LEDs on all GPIOs, a relay, a buzzer, LDR, a socket for NRF240 modules, CH340 USB to Serial converter and DIP switches allowing different IO routing configurations to be setup. A small adapter board connects the normal ESP8266 modules to a pair of 2x4 headers. The board is widely available from a number of Chinese vendors. | + | The AI-Thinker board is an evaluation board with an onboard STC15L204EA microcontroller along with a relay, buttons and LEDs on all GPIOs, a relay, a buzzer, LDR, a socket for NRF240 modules, CH340 USB to Serial converter and DIP switches allowing different IO routing configurations to be setup. A small adapter board connects the normal ESP8266 modules to a pair of 2x4 headers. The board is widely available from a number of Chinese vendors, sometimes called a Coexistence Module. This is not the cheaper AI-Thinker "yellow board" (which should have its own entry on this page). |
=== DIP Switches === | === DIP Switches === | ||
Line 41: | Line 41: | ||
This is the right-most switch when the USB port is at top. Controls routing of some of the IO and signal lines. | This is the right-most switch when the USB port is at top. Controls routing of some of the IO and signal lines. | ||
- | | **No.** | **Label** | **Function** | | + | | **No.** | **Label** | **Function** | |
- | | 1 | GPIO14 | ? | | + | | 1 | GPIO14 | ON=AC relay controlled by ESP8266 GPIO14 | |
- | | 2 | DL_MCU | ? | | + | | 2 | DL_MCU | ON=AC relay controlled by MCU | |
- | | 3 | CH_PD_H | ON=Enable pull up on CH_PD line of ESP8266. | | + | | 3 | CH_PD_H | ON=Enable pull up on CH_PD line of ESP8266. | |
- | | 4 | GPIO0_H | ? | | + | | 4 | GPIO0_L | ON=Pull ESP8266 GPIO0 down for flashing. | |
- | | 5 | GPIO15_H | ? | | + | | 5 | GPIO15_L | ON=Pull ESP8266 GPIO15 down (normal during boot) | |
- | | 6 | GPIO2_H | ? | | + | | 6 | GPIO2_L | ON=Pull ESP8266 GPIO2 down for ? | |
+ | ===Relay=== | ||
+ | Normally open, it can bridge the two AC terminal connections together. See above for control. High level closes the relay. Handles 3 amps at 35v DC or 3 amps at 250v AC. | ||
+ | ===Buzzer=== | ||
+ | Annoying. Apparently controlled only by MCU? | ||
+ | ===CDS Light Sensor=== | ||
+ | One is installed on the board, connected to the MCU. Holes for another wired to the ESP8266 ADC are in place but not populated with a sensor presumably because this version breaks out the ADC for independent use. | ||
+ | ===Schematic=== | ||
+ | What is apparently an older version may be found in [[http://www.esp8266.com/viewtopic.php?f=13&t=480|this thread.]] |
