Next revision | Previous revision Next revision Both sides next revision | ||
esp8266_memory_map [2014/12/31 02:27] admin created |
esp8266_memory_map [2014/12/31 02:29] admin |
Line 1: | Line 1: | ||
+ | ** please someone fix up this page, needs an edit! ** | ||
====== ESP8266 Memory Map ====== | ====== ESP8266 Memory Map ====== | ||
Line 7: | Line 9: | ||
The reset vector is 40000080h, which maps to internal ROM. | The reset vector is 40000080h, which maps to internal ROM. | ||
- | ==== Memory Layout ==== | + | ===== Memory Layout ===== |
| Address | Name | Size | Type | R/W | Description | | | Address | Name | Size | Type | R/W | Description | | ||
Line 62: | Line 63: | ||
| 7E000h | 8k | blank.bin | Filled with FFh. May be WiFi configuration. | | | 7E000h | 8k | blank.bin | Filled with FFh. May be WiFi configuration. | | ||
- | === Exception Vectors === | + | ==== Exception Vectors ==== |
