esp8266_power_usage [2015/06/16 09:08] tytower [7.system_deep_sleep_set_option] |
esp8266_power_usage [2015/06/23 19:41] tytower [More data from expressif] |
Line 56: | Line 56: | ||
</code> | </code> | ||
- | There are couple modifications to be made: one required, one suggested. To wake itself up, the ESP8266 uses the XPD pin to trigger its reset line so those two pins need to be connected together. Wiring up XPD to DTR works. ( Note there is a small capacitor between them on Sparkfuns Thing board on the DTR line) | + | To wake itself up, the ESP8266 uses the XPD pin to trigger its reset line so those two pins need to be connected together. XPD_DCDC connects to EXT_RSTB with 0R\\ |
+ | Wiring up XPD to DTR works. ( Note there is a small capacitor between them on Sparkfuns Thing board on the DTR line) | ||
===== More data from expressif ===== | ===== More data from expressif ===== | ||
- | can be found at \\ [[http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379|http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379]] | + | can be found at \\ [[http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379|http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379]]// |
+ | [[http://bbs.espressif.com/viewtopic.php?f=21&t=645|http://bbs.espressif.com/viewtopic.php?f=21&t=645]]// | ||
- | An extract from which deals with deep sleep \\ | + | An extract from which deals with deep sleep // |
- | ==== 6.system_deep_sleep ==== | + | ==== 6.system_deep_sleep ==== // |
**__Function:__** \\ Configures chip for deep-sleep mode. When the device is in deep-sleep, it automatically wakes up periodically; the period is configurable. Upon waking up, the device boots up from user_init.\\ | **__Function:__** \\ Configures chip for deep-sleep mode. When the device is in deep-sleep, it automatically wakes up periodically; the period is configurable. Upon waking up, the device boots up from user_init.\\ | ||
Line 84: | Line 86: | ||
**__Note:__** \\ Init data refers esp_init_data_default.bin.\\ | **__Note:__** \\ Init data refers esp_init_data_default.bin.\\ | ||
**__Return:__**\\ | **__Return:__**\\ | ||
- | true : succeed........ false : fail\\ | + | true : succeed........ false : fail // |
