lua [2014/12/19 15:54] harold_l |
lua [2015/06/06 21:56] terrye [NodeMCU] Typo |
Line 1: | Line 1: | ||
- | ====== LUA ====== | + | ====== Lua ====== |
- | As lua.org was saying, Lua is a powerful, fast, lightweight, embeddable scripting language. Lua combines simple procedural syntax with powerful data description constructs based on associative arrays and extensible semantics. | + | |
- | * Lua is small: the Lua interpreter easily fits in under 100 kilobytes including the base libraries. | + | There are 2 "branches:" of Lua now for ESP8266, and both are now open source. Confusingly, both use the word Node in their name - NodeLua and NodeMcu! |
- | * Lua is fast: independent benchmarks show that Lua is often amongst the fastest interpreted dynamic languages. The Lua interpreter has been extensively tuned for high performance. | + | As [[http://lua.org|lua.org]] says, Lua is a powerful, fast, lightweight, embeddable scripting language. Lua combines simple procedural syntax with powerful data description constructs based on associative arrays and extensible semantics. |
- | ==== Tools and Firmwares on ESP8266 ==== | + | * Lua is small: the Lua interpreter easily fits in under 100 kilobytes including the base libraries. |
+ | * Lua is fast: independent benchmarks show that Lua is often amongst the fastest interpreted dynamic languages. The Lua interpreter has been extensively tuned for high performance. | ||
+ | ===== NodeMCU ===== | ||
+ | * [[NodeMCU]] - Initially this was closed source, but was released to open-source in October 2014. This firmware is based on the [[http://www.eluaproject.net/overview|eLua]] platform and migrated to the ESP8266 and SDK.It is under active development by esp8266 open source community. It helps you to prototype your IOT product within a few Lua script lines. | ||
+ | ===== NodeLua ===== | ||
* [[NodeLua]] - A open source firmware runs Lua code on ESP8266, written by Harold L. | * [[NodeLua]] - A open source firmware runs Lua code on ESP8266, written by Harold L. | ||
- | * [[Node WebIDE]] - A pure web-based tool works with [[NodeLua]] for Lua programming and run codes on ESP8266 over-the-air. | + | * [[NodeLua WebIDE]] - A pure web-based tool works with [[NodeLua]] for Lua programming and run codes on ESP8266 over-the-air. |
+ | * This project is now moribund with the last updates over 6 months ago. | ||
