start [2016/05/20 07:52] ajvdw [ESP8266.com Users Projects] |
start [2021/01/08 13:29] michaeljordig |
Line 1: | Line 1: | ||
- | ====== Welcome to the ESP8266 Community Wiki ====== | + | Most of the time, SEO makes a speciality of keywords. The intention is to add relevant key phrases to the internet site so that better ratings are performed and visitors is captured whilst internet users search for the relevant term. |
+ | However, seek traits have developed over time. Instead of typing in a quick keyword or phrase, internet customers are typing in longer, extra precise phrases, questions, or even the use of speech-to-textual content features and gadgets to submit a search question. | ||
- | [[:start?do=register|Register to edit the Wiki]] | + | As a result, SEO has turn out to be greater complex. This is why semantic search engine optimization is a crucial a part of an standard optimization plan. |
- | [[https://twitter.com/intent/follow?original_referer=http%3A%2F%2Fwww.esp8266.com%2Findex.php%3Fsid%3Db5d9188418cf2f8dd8ce08ddd2b3d489®ion=follow_link&screen_name=esp8266com&tw_p=followbutton|Follow on Twitter]] for the latest NEWS. | + | With semantic search engine marketing, the focus isn’t just on creating key phrases to feature to the internet site. Creating textual content that’s actually full of keyword instances is not going to be effective. |
- | + | [[[[https://www.dyifo.com/is-your-website-content-thematically-relevant/|Semantic SEO]]]] | |
- | Also on [[https://www.facebook.com/esp8266com|Facebook]] | + | |
- | The game plan for this page is to make it a Table Of Contents for the rest of the WIKI, then links off the TOC will take you to the real information. Try to not bury info either, one level deep off the TOC for most things and 2 levels for the things that really need it. | + | |
- | USE imaginative URLs and page names for better Google Indexing! | + | |
- | People can start making a skeleton TOC and then others can fill in the missing pages that link off of the TOC. | + | |
- | Please visit [[http://www.esp8266.com|The ESP8266 Community Forum]] to chat with others about this wonderful IC! | + | |
- | ===== Table of Contents ===== | + | |
- | ==== Available Hardware ==== | + | |
- | * [[esp8266-module-family|Modules]] | + | |
- | * [[esp8266-test-boards|Test Boards]] | + | |
- | * [[esp8266-dev-boards| Development Boards]] | + | |
- | * [[where-to-buy | Where to buy]] | + | |
- | ==== Device Overview ==== | + | |
- | * {{:0A-ESP8266__Datasheet__EN_v4.3.pdf|New English Espressif June 2015 ESP8266 Datasheet PDF}} | + | |
- | * {{:esp8266_specifications_english.pdf|Original Espressif October 2013 ESP8266 Datasheet PDF}} | + | |
- | * [[Feature Set]] | + | |
- | * [[Device architecture]] | + | |
- | * [[Program Execution]] | + | |
- | * [[Bootloader and Programming Interface]] | + | |
- | * [[JTAG Debug Interface]] | + | |
- | * [[ESP8266 GPIO Registers]] | + | |
- | * [[ESP8266 GPIO Pin Allocations]] | + | |
- | * [[ESP8266 Memory Map]] | + | |
- | * [[ESP8266 Power Usage]] | + | |
- | ==== ESP8266 On-Chip development ==== | + | |
- | * [[Toolchain]] | + | |
- | * [[Loading Firmware]] | + | |
- | * [[Hardware SPI Information]] | + | |
- | * [[Mode Changes]] | + | |
- | ==== ESP8266 Compiler Setup and Usage ==== | + | |
- | * [[Windows setup-windows-compiler-esp8266|Visual Studio IDE]] | + | |
- | * [[setup-OSX-compiler-esp8266|OSX]] | + | |
- | http://sakacamprung.blogspot.co.id/2016/05/jelly-gamat-qnc.html | + | |
- | ==== AT Command Set ==== | + | |
- | * [[AT Commands]] | + | |
- | * [[IGRR's AT Commands]] | + | |
- | ==== Getting Started ==== | + | |
- | * [[getting-started-with-the-esp8266|ESP8266 101]] | + | |
- | * [[start-with-esp-12-arduino|Start with the ESP-1 and the Arduino tools]] | + | |
- | ==== Platforms ==== | + | |
- | * [[Lua]] | + | |
- | * [[ESP8266Basic]] | + | |
- | * [[Espruino JavaScript]] | + | |
- | ==== Integrations ==== | + | |
- | * [[raspberrypi-Integration-with-esp8266|Raspberry Pi & ESP8266]] | + | |
- | ==== ESP8266.com Users Projects ==== | + | |
- | * [[http://web.ncf.ca/fp927/esp/|Micro's Getting Started with LUA]] | + | |
- | * [[wonderfulm3]] | + | |
- | * [[esp-httpd]] | + | |
- | * [[esp_mqtt]] - Native MQTT client (SSL Support) | + | |
- | * [[espduino]] - MQTT client for Arduino over ESP8266 (AT Command) | + | |
- | * [[esp8266-frankenstein]] - Alternative firmware with commandline interface | + | |
- | * [[xpl-esp8266]] - Example using FreeRTOS SDK | + | |
- | * [[https://github.com/tjclement/esp-dimmer-hardware|esp-wifi-dimmer]] - A $5 super tiny Wifi LED Dimmer | + | |
- | * [[http://jumpwire.io/|jumpwire.io]] - Free messaging cloud service with Websocket client for Arduino over ESP8266 (AT Command) | + | |
- | * [[ https://github.com/ajvdw/HexAJpod]] - ESP8266 based Hexapod | + | |
- | * [[Esp8266_and_SD_Cards]] | + | |
- | * [[ http://tech.scargill.net/esp8266-arduino-netio-server-demo/]] ESP8266 Arduino NetIO Server/Servo Demo | + | |
- | * [[ https://www.supla.org|SUPLA]] - Open Source building automation system based on ESP8266 | + | |
- | * [[ https://github.com/SUPLA/ESP8266|SUPLA - Firmware]] - WiFi-Socket firmware and Gate-Module firmware based on SUPLA project | + | |
- | * http://sakacamprung.blogspot.co.id/2016/05/jelly-gamat-qnc.html | + |
