====== ESP-HTTPD ====== [[http://www.esp8266.com/viewtopic.php?f=6&t=376|esp-httpd]] is a web server running directly on the ESP8266, created by [[User:Sprite_tm]]. ==== Building it ==== Let's use ESP8266. It makes things way easier. You can clone the esp-httpd repo from [[http://git.spritesserver.nl/esphttpd.git/]]. Once you do that, you should fix the following patch to point to your esp-open-sdk installation and apply it to the Makefile. You also need esptool, the C one. Here's [[https://github.com/esp8266/esp8266-wiki/raw/master/deb/src/esptool_0.0.2.orig.tar.gz|the tarball]]. The binary's in there. Just point the ESPTOOL variable at the binary. diff --git a/Makefile b/Makefile index 5545fc9..3ff077d 100644 --- a/Makefile +++ b/Makefile @@ -12,17 +12,17 @@ BUILD_BASE = build FW_BASE = firmware # Base directory for the compiler -XTENSA_TOOLS_ROOT ?= /opt/Espressif/crosstool-NG/builds/xtensa-lx106-elf/bin +XTENSA_TOOLS_ROOT ?= /home/liam/projects/esp8266/esp-open-sdk/xtensa-lx106-elf/bin #Extra Tensilica includes from the ESS VM -SDK_EXTRA_INCLUDES ?= /opt/Espressif/include -SDK_EXTRA_LIBS ?= /opt/Espressif/arch/lib +SDK_EXTRA_INCLUDES ?= /home/liam/projects/esp8266/esp-open-sdk/sdk/include +SDK_EXTRA_LIBS ?= /home/liam/projects/esp8266/esp-open-sdk/sdk/lib # base directory of the ESP8266 SDK package, absolute -SDK_BASE ?= /opt/Espressif/ESP8266_SDK +SDK_BASE ?= /home/liam/projects/esp8266/esp-open-sdk/esp_iot_sdk_v0.9.3 #Esptool.py path and port -ESPTOOL ?= esptool +ESPTOOL ?= /home/liam/projects/esp8266/esptool/esptool ESPPORT ?= /dev/ttyUSB0 #ESPDELAY indicates seconds to wait between flashing the two binary images ESPDELAY ?= 3
