ESP8266 Support WIKI
User Tools
Site Tools
Command disabled: login
arduino-docs
Table of Contents
Arduiono IDE for ESP8266
Basic Arduino functions and classes
Standard Libs
Wire
content
EEPROM
EEPROM functionality is similar to the standard Arduino library with the exception of having to declare memory size and committing writes.
example
#include <EEPROM.h>
void setup()
     //Init EEPROM, note the size requirement. I believe 4096B is the maximum available.
     //You could use a smaller amount/size.
     EEPROM.begin(4096);
     for( int i = 0; i < 4096; i++ )
          EEPROM.write(i,i);
     EEPROM.commit(); //note here the commit!
NOTE: EEPROMAnything can be used with one simple modification. Find the EEPROMAnything.h and add EEPROM.commit(); after the EEPROM.write(ee++, *p++);
EEPROMAnything provides nice functionality to save any type of variable including structers.
#include <EEPROMAnything.h>
struct eepromInfoType
     uint8_t MyUnsigned8BitInt;
     char MyCharArray[25]
} myStructOriginal, myStructCopy;
void setup()
     myStructOriginal.MyUnsigned8BitInt = 0; //assign some value
     strcpy( myStructOriginal.MyCharArray, "Less than 25 chars" ); //assign some value
     EEPROM_writeAnything( 0, myStructOriginal ); //remember to modify EEPROM_writeAnything by adding   .commit().
     //Lets read it back
     EEPROM_readAnything( 0, myStructCopy );
void loop()
//nothing here
ESP Specific Libs
SDK-API (1.0.0)
If you want to use some the the SDK-API functions have a look at this link http://bbs.espressif.com/viewtopic.php?f=5&t=286
The Documentation can be found here http://bbs.espressif.com/download/file.php?id=253
To use the API you have to include some header-files in your sketch. Below is a quick example of using the RTC-Memory-Write API to make a counter persistent even after using sleep + the following reset.
#include <Streaming.h>
// Include API-Headers
extern "C" {
#include "ets_sys.h"
#include "os_type.h"
#include "osapi.h"
#include "mem.h"
#include "user_interface.h"
#include "cont.h"
// Counter
uint32_t i = 0;
// Temporary buffer
uint32_t b = 0;
  // Call API-Function
  system_deep_sleep_set_option(4);
  system_rtc_mem_read(64,&b,4) << endl;
  // Check if the value is within expected range
  if(b < 100000)
    i = b;
int lap = 0;
  for(int c = 0; c < 50; c++)
    Serial << i++ << " " << lap << endl;
    delay(10);
  system_rtc_mem_write(64,&i,4) << endl;
  delay(1000);
  system_deep_sleep(10000000);
  lap++;
ESP8266WiFi
Connect with static IP
If you experience problems regarding DNS resolving check out https://github.com/esp8266/Arduino/issues/369
#include <WiFiClient.h>
#include <IPAddress.h>
const char* ssid = ".....";
const char* password = ".....";
void setup(void)
  // Connect to WiFi network
  WiFi.begin(ssid, password);
  //set static ip part
  WiFi.config(IPAddress(192,168,1,118), IPAddress(192,168,1,1), IPAddress(255,255,255,0));
  // Wait for connection
    delay(200);
ESP8266mDNS
content
ESP8266WebServer
content
arduino-docs.txt · Last modified: 2015/07/19 01:19 by apedro
Page Tools
