arduino-integration-with-esp8266 [2015/06/14 22:40] tytower [Tutorials] |
arduino-integration-with-esp8266 [2015/06/14 22:43] tytower [Tutorials] |
Line 5: | Line 5: | ||
* [[Connect to ESP8266 ONLY using Arduino Uno]] | * [[Connect to ESP8266 ONLY using Arduino Uno]] | ||
Note - An arduino board is not needed usually as the ESP8266 has 16 times the memory and 5 times the speed . | Note - An arduino board is not needed usually as the ESP8266 has 16 times the memory and 5 times the speed . | ||
- | 32KB for the UNO Flash and it operates at 16 Mhz | + | |
- | 512 KB for the ESP8266 and it operates at 80 Mhz (Up to 4Mb and 160Mhz on some) | + | 32KB for the UNO Flash and it operates at 16 Mhz. |
+ | 512 KB for the ESP8266 and it operates at 80 Mhz. (Up to 4Mb and 160Mhz on some). | ||
+ | Its limitation is its IO pins . Most have but one Analog pin but many Digital pins | ||
===== Libraries ===== | ===== Libraries ===== |
