arduino-integration-with-esp8266 [2015/06/13 19:16] tytower [Libraries] |
arduino-integration-with-esp8266 [2015/06/14 22:43] (current) tytower [Tutorials] |
Line 4: | Line 4: | ||
* [[Connect to ESP8266 ONLY using Arduino Uno]] | * [[Connect to ESP8266 ONLY using Arduino Uno]] | ||
+ | Note - An arduino board is not needed usually as the ESP8266 has 16 times the memory and 5 times the speed . | ||
+ | 32KB for the UNO Flash and it operates at 16 Mhz. | ||
+ | 512 KB for the ESP8266 and it operates at 80 Mhz. (Up to 4Mb and 160Mhz on some). | ||
+ | Its limitation is its IO pins . Most have but one Analog pin but many Digital pins | ||
===== Libraries ===== | ===== Libraries ===== | ||
- | * [[ESP8266/Arduino Maintained by IGRR https://github.com/esp8266/Arduino|https://github.com/esp8266/Arduino]] | + | * [[ESP8266/Arduino Maintained by IGRR ]] |
* [[arduino:diaoul|Diaoul's ESP8266 library]] | * [[arduino:diaoul|Diaoul's ESP8266 library]] | ||
* [[https://github.com/itead/ITEADLIB_Arduino_ESP8266|ITEAD Studio's ESP8266 library]] | * [[https://github.com/itead/ITEADLIB_Arduino_ESP8266|ITEAD Studio's ESP8266 library]] | ||
