connect_to_esp8266_only_using_arduino_uno [2014/12/31 18:17] en10 |
connect_to_esp8266_only_using_arduino_uno [2014/12/31 18:26] en10 |
Line 6: | Line 6: | ||
**BE ADVISED** that the ESP8266 is rated at 3.3V and the UNO RX and TX pins are rated as 5V but i've had no issues so far. | **BE ADVISED** that the ESP8266 is rated at 3.3V and the UNO RX and TX pins are rated as 5V but i've had no issues so far. | ||
- | {{::arduinouno_r3_front_450px_1_.jpg?200|}} {{:esp8266_pinout_h-569x236_1_.png?200|}} | + | {{::arduinouno_r3_front_450px_1_.jpg?300|}} {{:esp8266_pinout_h-569x236_1_.png?300|}} |
I connected them as follows: | I connected them as follows: | ||
Line 16: | Line 16: | ||
* 3.3V --- CH_PD | * 3.3V --- CH_PD | ||
- | Breadboard may be required to connect both VCC and CG_PD to 3.3V pin | + | Breadboard may be required to connect both VCC and CG_PD to 3.3V pin. |
I loaded the BareMinimum sketch, so that no previous sketch causes issues. | I loaded the BareMinimum sketch, so that no previous sketch causes issues. | ||
- | Once Connected open the Serial Monitor and set Baud to 9600. | + | ---- |
+ | Once Connected open the Serial Monitor and set "Both NL & CR" and Baud to 9600. | ||
Send "AT" to test. If nothing comes up try different baud rates such as 115200 or 57600 and retest. | Send "AT" to test. If nothing comes up try different baud rates such as 115200 or 57600 and retest. | ||
If you get "OK" reply then all is working. | If you get "OK" reply then all is working. | ||
List of commands can be found here: | List of commands can be found here: |
