Both sides previous revision Previous revision | Last revision Both sides next revision | ||
esp-12_board_to_thingspeak_and_sparkfun [2015/05/30 20:45] tytower |
esp-12_board_to_thingspeak_and_sparkfun [2015/06/11 22:38] tytower |
Line 1: | Line 1: | ||
+ | Here is a program to run on the ESP8266-12 or similar which sends the readings from BMP180 and DHT22 to Thingspeak and to Sparkfun , has an error LED and 2 digital pins and one analog pin left over. You can view the data streams at | ||
+ | https://data.sparkfun.com/streams/RMzp9ANyqzfjw4drzNnZ | ||
+ | https://thingspeak.com/channels/38247 | ||
+ | http://www.esp8266.com/download/file.php?id=1089 | ||
Arduino Development and files available here [[http://www.esp8266.com/viewtopic.php?f=6&t=2872|http://www.esp8266.com/viewtopic.php?f=6&t=2872]] | Arduino Development and files available here [[http://www.esp8266.com/viewtopic.php?f=6&t=2872|http://www.esp8266.com/viewtopic.php?f=6&t=2872]] | ||
Board has two sensors connected , BMP180 and DHT22 , sending data to both servers ,Thingspeak and Sparkfun to record temperature ,humidity and pressure. | Board has two sensors connected , BMP180 and DHT22 , sending data to both servers ,Thingspeak and Sparkfun to record temperature ,humidity and pressure. |
