ESP8266 Support WIKI
User Tools
Site Tools
esp-12_board_to_thingspeak_and_sparkfun
Differences
Link to this comparison view
Both sides previous revision Previous revision
esp-12_board_to_thingspeak_and_sparkfun [2015/06/11 22:38]
tytower
esp-12_board_to_thingspeak_and_sparkfun [2015/06/18 08:11] (current)
yeti please don't plenk
Line 1: Line 1:
- Here is a program to run on the ESP8266-12 or similar which sends the readings from BMP180 and DHT22 to Thingspeak and to Sparkfun , has an error LED and 2 digital pins and one analog pin left over. You can view the data streams at+Here is a program to run on the ESP8266-12 or similar which sends the readings from BMP180 and DHT22 to Thingspeak and to Sparkfun, has an error LED and 2 digital pins and one analog pin left over. You can view the data streams at
 https://​data.sparkfun.com/​streams/​RMzp9ANyqzfjw4drzNnZ https://​data.sparkfun.com/​streams/​RMzp9ANyqzfjw4drzNnZ
 https://​thingspeak.com/​channels/​38247 https://​thingspeak.com/​channels/​38247
Line 11: Line 11:
-Board has two sensors connected , BMP180 and DHT22 , sending data to both servers ,Thingspeak and Sparkfun to record temperature ,humidity and pressure.+Board has two sensors connected, BMP180 and DHT22, sending data to both servers,​Thingspeak and Sparkfun to record temperature,​ humidity and pressure.
esp-12_board_to_thingspeak_and_sparkfun.1434062304.txt.gz · Last modified: 2015/06/11 22:38 by tytower
