esp8266-module-family [2017/05/14 17:15] bluejedi [Summary Table] |
esp8266-module-family [2018/04/01 04:07] kernelmode |
Line 1: | Line 1: | ||
====== Modules ====== | ====== Modules ====== | ||
Most common modules ESP-NN seem to come from AI-Thinkers vendor. Espressif Systems themselves have produced the ESP-WROOM-02 Wi-Fi Module. | Most common modules ESP-NN seem to come from AI-Thinkers vendor. Espressif Systems themselves have produced the ESP-WROOM-02 Wi-Fi Module. | ||
+ | All Modules by AI-Thinker : see [[http://wiki.ai-thinker.com/_media/esp8266/esp8266_module_list.png]] | ||
+ | * 推荐型号 (Green) : Recommended Model | ||
+ | * 停产型号 (Gray) : Discontinued Model | ||
+ | Product Specification : [[http://wiki.ai-thinker.com/esp8266/docs]] | ||
+ | User Manual : [[http://wiki.ai-thinker.com/_media/esp8266/a000um01a3.pdf]] | ||
There are also modules from other vendors, such as : | There are also modules from other vendors, such as : | ||
Line 50: | Line 58: | ||
^ Pin ^ Name ^ Alternate Functions ^ Notes ^ | ^ Pin ^ Name ^ Alternate Functions ^ Notes ^ | ||
- | | 1 | GND | | (Pin 1 is in the corner close to the xtal and away from antenna) | | + | | 1 | GND | | (Pin 1 is in the corner close to the crystal and away from antenna) | |
| 2 | NC | | | | | 2 | NC | | | | ||
| 3 | UTXD | SPICS1, GPIO1, CLK\_RTC | Typically used as serial uart0 TX | | | 3 | UTXD | SPICS1, GPIO1, CLK\_RTC | Typically used as serial uart0 TX | | ||
Line 101: | Line 109: | ||
{{:08-04.jpg?200|}} | {{:08-04.jpg?200|}} | ||
- | Two version of ESP-08 are on market one whit 7x2 pins (like one on picture) and probably new one with 8x2+ant pins (pinout is same like new 8x2 ESP-07) | + | Two versions of ESP-08 are on the market: one with 7x2 pins (like the one in the picture) and probably a new one with 8x2+ant pins (pinout is the same like the new 8x2 ESP-07) |
{{:modules:s-l500.jpg?200|}} | {{:modules:s-l500.jpg?200|}} | ||
Line 183: | Line 191: | ||
{{ esp8266-14_backside.jpg?300 |}} | {{ esp8266-14_backside.jpg?300 |}} | ||
Backside of the ESP8266-14 module. | Backside of the ESP8266-14 module. | ||
- | The ESP8266-14 module has pins and connection on three sides of the board | + | The ESP8266-14 module has pins and connections on three sides of the board |
{{ esp8266-14_shieldremoved.jpg?640 |}} | {{ esp8266-14_shieldremoved.jpg?640 |}} | ||
Line 206: | Line 214: | ||
===== Summary Table ===== | ===== Summary Table ===== | ||
- | ^ Board ID ^ #Pins ^ Pitch ^ Form factor ^ #LEDs ^ Antenna ^ Ant.Socket ^ Shielded ^ Dimensions mm ^ Flash Size in Bytes and (bits) ^ | + | ^ Board ID ^ #Pins ^ Pitch ^ Form factor ^ LEDs ^ Antenna ^ Ant.Socket ^ Shielded ^ Dimensions mm ^ Flash Size in Bytes and (bits) ^ |
- | | ESP-01 | 8 | .1" | 2x4 DIL | Yes | Etched-on PCB | No | No | 14.3 x 24.8 | 512KB (4Mb) ×× | | + | | ESP-01 | 8 | 0.1" | 2x4 DIL | Yes | Etched-on PCB | No | No | 14.3 x 24.8 | 512KB (4Mb) ×× | |
- | | ESP-02 | 8 | .1" | 2x4 notch | No? | None | Yes | No | 14.2 x 14.2 | 512KB (4Mb) × | | + | | ESP-02 | 8 | 0.1" | 2x4 notch | No? | None | Yes | No | 14.2 x 14.2 | 512KB (4Mb) × | |
| ESP-03 | 14 | 2mm | 2x7 notch | No | Ceramic| No | No | 17.3 x 12.1 | 512KB (4Mb) × | | | ESP-03 | 14 | 2mm | 2x7 notch | No | Ceramic| No | No | 17.3 x 12.1 | 512KB (4Mb) × | | ||
| ESP-04 | 14 | 2mm | 2x4 notch | No? | None | No | No | 14.7 x 12.1 | 512KB (4Mb) × | | | ESP-04 | 14 | 2mm | 2x4 notch | No? | None | No | No | 14.7 x 12.1 | 512KB (4Mb) × | | ||
- | | ESP-05 | 5 | .1" | 1x5 SIL | No | None | Yes | No | 14.2 x 14.2 | 512KB (4Mb) × | | + | | ESP-05 | 5 | 0.1" | 1x5 SIL | No | None | Yes | No | 14.2 x 14.2 | 512KB (4Mb) × | |
| ESP-06 | 12+GND | misc | 4x3 dice | No | None | No | Yes | 16.3 x 13.1 | 512KB (4Mb) × | | | ESP-06 | 12+GND | misc | 4x3 dice | No | None | No | Yes | 16.3 x 13.1 | 512KB (4Mb) × | | ||
| ESP-07 | 16 | 2mm | 2x8 pinhole | Yes | Ceramic | Yes | Yes | 21.2 x 16.0 | 1MB (8Mb) ×× | | | ESP-07 | 16 | 2mm | 2x8 pinhole | Yes | Ceramic | Yes | Yes | 21.2 x 16.0 | 1MB (8Mb) ×× | | ||
- | | ESP-07S | 16 | 2mm | 2x8 pinhole | No | None | Yes | Yes | 17.0 x 16.0 | ? 1MB (8Mb) ? | | + | | ESP-07S | 16 | 2mm | 2x8 pinhole | No | None | Yes | Yes | 17.0 x 16.0 | 4MB (32Mb) | |
- | | ESP-08 | 14 | 2mm | 2x7 notch | No | None | No | Yes | 17.0 x 16.0 | ? Please fill if you know ? | | + | | ESP-08 | 14 | 2mm | 2x7 notch | No | None | No | Yes | 17.0 x 16.0 | ?? //(please fill if you know)// | |
- | | ESP-08 New | 16 | 2mm | 2x8 notch | No | None | No | Yes | 18.0 x 16.0 | ? Please fill if you know ? | | + | | ESP-08 New | 16 | 2mm | 2x8 notch | No | None | No | Yes | 18.0 x 16.0 | ?? //(please fill if you know)// | |
- | | ESP-09 | 12+GND | misc | 4x3 dice | No | None | No | No | 10.0 x 10.0 | ? Please fill if you know ? | | + | | ESP-09 | 12+GND | misc | 4x3 dice | No | None | No | No | 10.0 x 10.0 | 1MB (8Mb) | |
- | | ESP-10 | 5 | 2mmm? | 1x5 notch | No | None | No | No | 14.2 x 10.0 | 512KB (4Mb) * | | + | | ESP-10 | 5 | 2mm //??// | 1x5 notch | No | None | No | No | 14.2 x 10.0 | 512KB (4Mb) * | |
| ESP-11 | 8 | 1.27mm| 1x8 pinhole | No? | Ceramic | No | No | 17.3 x 12.1 | 512KB (4Mb) * | | | ESP-11 | 8 | 1.27mm| 1x8 pinhole | No? | Ceramic | No | No | 17.3 x 12.1 | 512KB (4Mb) * | | ||
- | | ESP-12 | 16 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | ? 4MB (32Mb) ? | | + | | ESP-12 | 16 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) //??// | |
- | | ESP-12-F | 22 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) | | + | | ESP-12F | 22 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) | |
- | | ESP-12-E | 22 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) | | + | | ESP-12E | 22 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) | |
| ESP-12S | 16 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) | | | ESP-12S | 16 | 2mm | 2x8 notch | Yes | Etched-on PCB | No | Yes | 24.0 x 16.0 | 4MB (32Mb) | | ||
| ESP-13 | 18 | 1.5mm | 2x9 | ? | Etched-on PCB | No | Yes | 20.0 x 19.9 | 4MB (32Mb) | | | ESP-13 | 18 | 1.5mm | 2x9 | ? | Etched-on PCB | No | Yes | 20.0 x 19.9 | 4MB (32Mb) | | ||
- | | ESP-14 | 22 | 2mm | 2x8 + 6 | 1 | Etched-on PCB | No | Yes | 24.3 x 16.2 | ? Please fill if you know ? | | + | | ESP-14 | 22 | 2mm | 2x8 + 6 | 1 | Etched-on PCB | No | Yes | 24.3 x 16.2 | ?? //(please fill if you know)// | |
| ESP-201 | 22+4 | 0.1" | 2x11 + 4 | 2 | Etched-on PCB ××× | Yes | No | 33.5 x 25.5 | 512KB (4Mb) | | | ESP-201 | 22+4 | 0.1" | 2x11 + 4 | 2 | Etched-on PCB ××× | Yes | No | 33.5 x 25.5 | 512KB (4Mb) | | ||
- | | WROOM-02 | 18 | 1.5mm | 2x9 | No | Etched on PCB | No | Yes | 20.0 x 18.0 | ? Please fill if you know ? | | + | | WROOM-02 | 18 | 1.5mm | 2x9 | No | Etched on PCB | No | Yes | 20.0 x 18.0 | ?? //(please fill if you know)// | |
| WT8266-S1 | 18 | 1.5mm | 3x6 | 1 | Etched on PCB | No | Yes | 15.0 x 18.6| 4MB (32Mb) | | | WT8266-S1 | 18 | 1.5mm | 3x6 | 1 | Etched on PCB | No | Yes | 15.0 x 18.6| 4MB (32Mb) | | ||
- | **× New firmwares can be flashed only on boards with at least 1MB (8Mb) flash.** | + | **× New firmwares can only be flashed on boards with at least 1MB (8Mb) flash.** |
- | **×× May be different on different editions of this board.** | + | **×× May be different on different editions of the board.** |
- | **××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor in the corresponding position.** | + | **××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** |
