Both sides previous revision Previous revision | Last revision Both sides next revision | ||
esp8266-module-family [2018/04/01 04:07] kernelmode |
esp8266-module-family [2018/04/01 04:10] kernelmode [Summary Table] |
Line 241: | Line 241: | ||
**×× May be different on different editions of the board.** | **×× May be different on different editions of the board.** | ||
**××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** | **××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** | ||
+ | more products : [[http://wiki.ai-thinker.com/_media/esp8266/esp8266_module_list.png]] |
