esp8266-module-family [2018/04/01 04:07] kernelmode |
esp8266-module-family [2021/06/24 19:59] aardwolf21 |
Line 146: | Line 146: | ||
** CE of ESP-12 ** | ** CE of ESP-12 ** | ||
CE NUMBER: BCTC-141212468 | CE NUMBER: BCTC-141212468 | ||
{{:esp-12_ce.jpg?600|}} | {{:esp-12_ce.jpg?600|}} | ||
+ | Note:This is not an EU CE declaration of conformity, This is a test pass certificate from a third party test company that has no official standing. An official EU DoC must be made by the manufacturer not a third party. Also note safety standard EN60950 does not exist, and has not for many many years. The R&TTE directive quoted ceased to be valid in 2016. These comments and similar apply to a lot of the certificates on this page. | ||
===== ESP-12F ===== | ===== ESP-12F ===== | ||
Line 241: | Line 244: | ||
**×× May be different on different editions of the board.** | **×× May be different on different editions of the board.** | ||
**××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** | **××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** | ||
+ | more products : [[http://wiki.ai-thinker.com/_media/esp8266/esp8266_module_list.png]] |
