esp8266-module-family [2017/07/25 07:56] bluejedi ESP-07S memory updated |
esp8266-module-family [2018/04/01 04:10] (current) kernelmode [Summary Table] |
Line 1: | Line 1: | ||
====== Modules ====== | ====== Modules ====== | ||
Most common modules ESP-NN seem to come from AI-Thinkers vendor. Espressif Systems themselves have produced the ESP-WROOM-02 Wi-Fi Module. | Most common modules ESP-NN seem to come from AI-Thinkers vendor. Espressif Systems themselves have produced the ESP-WROOM-02 Wi-Fi Module. | ||
+ | All Modules by AI-Thinker : see [[http://wiki.ai-thinker.com/_media/esp8266/esp8266_module_list.png]] | ||
+ | * 推荐型号 (Green) : Recommended Model | ||
+ | * 停产型号 (Gray) : Discontinued Model | ||
+ | Product Specification : [[http://wiki.ai-thinker.com/esp8266/docs]] | ||
+ | User Manual : [[http://wiki.ai-thinker.com/_media/esp8266/a000um01a3.pdf]] | ||
There are also modules from other vendors, such as : | There are also modules from other vendors, such as : | ||
Line 50: | Line 58: | ||
^ Pin ^ Name ^ Alternate Functions ^ Notes ^ | ^ Pin ^ Name ^ Alternate Functions ^ Notes ^ | ||
- | | 1 | GND | | (Pin 1 is in the corner close to the xtal and away from antenna) | | + | | 1 | GND | | (Pin 1 is in the corner close to the crystal and away from antenna) | |
| 2 | NC | | | | | 2 | NC | | | | ||
| 3 | UTXD | SPICS1, GPIO1, CLK\_RTC | Typically used as serial uart0 TX | | | 3 | UTXD | SPICS1, GPIO1, CLK\_RTC | Typically used as serial uart0 TX | | ||
Line 101: | Line 109: | ||
{{:08-04.jpg?200|}} | {{:08-04.jpg?200|}} | ||
- | Two version of ESP-08 are on market one whit 7x2 pins (like one on picture) and probably new one with 8x2+ant pins (pinout is same like new 8x2 ESP-07) | + | Two versions of ESP-08 are on the market: one with 7x2 pins (like the one in the picture) and probably a new one with 8x2+ant pins (pinout is the same like the new 8x2 ESP-07) |
{{:modules:s-l500.jpg?200|}} | {{:modules:s-l500.jpg?200|}} | ||
Line 183: | Line 191: | ||
{{ esp8266-14_backside.jpg?300 |}} | {{ esp8266-14_backside.jpg?300 |}} | ||
Backside of the ESP8266-14 module. | Backside of the ESP8266-14 module. | ||
- | The ESP8266-14 module has pins and connection on three sides of the board | + | The ESP8266-14 module has pins and connections on three sides of the board |
{{ esp8266-14_shieldremoved.jpg?640 |}} | {{ esp8266-14_shieldremoved.jpg?640 |}} | ||
Line 217: | Line 225: | ||
| ESP-08 | 14 | 2mm | 2x7 notch | No | None | No | Yes | 17.0 x 16.0 | ?? //(please fill if you know)// | | | ESP-08 | 14 | 2mm | 2x7 notch | No | None | No | Yes | 17.0 x 16.0 | ?? //(please fill if you know)// | | ||
| ESP-08 New | 16 | 2mm | 2x8 notch | No | None | No | Yes | 18.0 x 16.0 | ?? //(please fill if you know)// | | | ESP-08 New | 16 | 2mm | 2x8 notch | No | None | No | Yes | 18.0 x 16.0 | ?? //(please fill if you know)// | | ||
- | | ESP-09 | 12+GND | misc | 4x3 dice | No | None | No | No | 10.0 x 10.0 | ?? //(please fill if you know)// | | + | | ESP-09 | 12+GND | misc | 4x3 dice | No | None | No | No | 10.0 x 10.0 | 1MB (8Mb) | |
| ESP-10 | 5 | 2mm //??// | 1x5 notch | No | None | No | No | 14.2 x 10.0 | 512KB (4Mb) * | | | ESP-10 | 5 | 2mm //??// | 1x5 notch | No | None | No | No | 14.2 x 10.0 | 512KB (4Mb) * | | ||
| ESP-11 | 8 | 1.27mm| 1x8 pinhole | No? | Ceramic | No | No | 17.3 x 12.1 | 512KB (4Mb) * | | | ESP-11 | 8 | 1.27mm| 1x8 pinhole | No? | Ceramic | No | No | 17.3 x 12.1 | 512KB (4Mb) * | | ||
Line 233: | Line 241: | ||
**×× May be different on different editions of the board.** | **×× May be different on different editions of the board.** | ||
**××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** | **××× Antenna connector is connected by default, to use PCB antenna switch (solder) the 0Ω resistor to the corresponding position.** | ||
+ | more products : [[http://wiki.ai-thinker.com/_media/esp8266/esp8266_module_list.png]] |
