Next revision | Previous revision Next revision Both sides next revision | ||
esp8266-test-boards [2015/01/25 21:22] gregware created |
esp8266-test-boards [2015/10/23 10:49] drum [Olimex ESP8266-EVB EValuation Board] |
Line 1: | Line 1: | ||
+ | ====== Boards ====== | ||
==== Node MCU ==== | ==== Node MCU ==== | ||
Node MCU who provides the LUA firmware also propose evaluation boards: | Node MCU who provides the LUA firmware also propose evaluation boards: | ||
Line 12: | Line 15: | ||
==== Olimex ESP8266-EVB EValuation Board ==== | ==== Olimex ESP8266-EVB EValuation Board ==== | ||
ESP8266-EVB is Evaluation board for ESP8266 with relay, button, UEXT, all GPIOs available on 0.1" header | ESP8266-EVB is Evaluation board for ESP8266 with relay, button, UEXT, all GPIOs available on 0.1" header | ||
- | [[https://www.olimex.com/Products/Modules/Ethernet/ESP8266-EVB/open-source-hardware]] | + | [[https://www.olimex.com/Products/IoT/ESP8266-EVB/]] |
+ | ==== AI-Thinker 'Test Board' ==== | ||
+ | The AI-Thinker board is an evaluation board with an onboard STC15L204EA microcontroller along with a relay, buttons and LEDs on all GPIOs, a relay, a buzzer, LDR, a socket for NRF240 modules, CH340 USB to Serial converter and DIP switches allowing different IO routing configurations to be setup. A small adapter board connects the normal ESP8266 modules to a pair of 2x4 headers. The board is widely available from a number of Chinese vendors. | ||
+ | === DIP Switches === | ||
+ | ==Serial Data Switch == | ||
+ | This is the left-most switch when the USB port is at top. Controls routing of the serial data lines. | ||
+ | | **No.** | **Label** | **Function** | | ||
+ | | 1 | DC_R_ON | ON=Connect ESP TX line to MCU RX line. | | ||
+ | | 2 | DC_T_ON | ON=Connect ESP RX line to MCU TX line. | | ||
+ | | 3 | ESP_T_ON | ON=Connect ESP TX line to CH340. | | ||
+ | | 4 | MCU_T_ON | ON=Connect MCU TX line to CH340. | | ||
+ | | 5 | ESP_R_ON | ON=Connect ESP RX line to CH340. | | ||
+ | | 6 | MCU_R_ON | ON=Connect MCU RX line to CH340. | | ||
+ | So, to achieve the following standard configurations set the dip switch as follows: | ||
+ | | **Configuration** | **1** | **2** | **3** | **4** | **5** | **6** | | ||
+ | | MCU connected to CH340 | OFF | OFF | OFF | ON | OFF | ON | | ||
+ | | ESP8266 connected to CH340 | OFF | OFF | ON | OFF | ON | OFF | | ||
+ | | MCU connected to ESP8266 | ON | ON | OFF | OFF | OFF | OFF | | ||
+ | ==IO Switch == | ||
+ | This is the right-most switch when the USB port is at top. Controls routing of some of the IO and signal lines. | ||
+ | | 1 | GPIO14 | ? | | ||
+ | | 2 | DL_MCU | ? | | ||
+ | | 3 | CH_PD_H | ON=Enable pull up on CH_PD line of ESP8266. | | ||
+ | | 4 | GPIO0_H | ? | | ||
+ | | 5 | GPIO15_H | ? | | ||
+ | | 6 | GPIO2_H | ? | | ||
