ESP8266 Support WIKI
User Tools
Site Tools
Command disabled: revisions
esp8266_memory_map
Table of Contents
ESP8266 Memory Map
This page describes the physical memory layout of the ESP8266 family.
Reset Vector
The reset vector is 40000080h, which maps to internal ROM.
Memory Layout
Address Name Size Type R/W Description
00000000h Exc Causes fault when reading.
20000000h No Unmapped, repeated pattern of 00 80 00 00.
3FF00000h dport0 1000h I/O RW? Memory-mapped I/O, repeated every 100h.
3FF10000h No Unmapped, zeroes.
3FF20000h ? ? RW? Unidentified data.
3FF30000h No Unmapped, zeroes.
3FFC0000h ? 20000h ? RW? uint32 mapping to the address it is located at. What is this?
3FFE0000h No Unmapped, zeroes.
3FFE8000h dram0 14000h RAM RW User data RAM. Available to applications.
3FFFC000h 4000h RAM ETS system data RAM.
40000000h brom? 10000h ROM RW? Internal ROM. May be writable somehow, but details unknown.
40010000h No Zeroes. Assumed to be unmapped.
40100000h iram1 8000h RAM RW Instruction RAM. Used by bootloader to load SPI Flash <40000h.
40108000h ? Zeroes.
40140000h ? Repeated pattern of 59 31 d8 ec.
40200000h ? SPI Flash is mapped here. Mapping hardware has 32KBytes cache (Unconfirmed). Non-cached code runs 12…13 times slower than code from IRAM. Cached code runs as fast as from IRAM. This area is readable as data with aligned 4-byte reads.
40300000h ? Unmapped, repeated pattern of 00 80 00 00.
60000000h ? 1000h I/O RW? Uncached I/O
60001000h ? 800h ? RW? Uncached I/O
60001800h ? 800h ? RW? Uncached. Mapped to 60001000h?
60002000h Exc Causes fault when reading.
70000000h 90000000h No Unmapped, repeated pattern of 00 80 00 00.
SPI Flash ROM Layout (without OTA upgrades)
Address Size Name Description
00000h 248k app.v6.flash.bin User application
3E000h 8k masterdevicekey.bin OTA device key. Unconfirmed: Not used without OTA
40000h 240k app.v6.irom0text.bin SDK libraries
7C000h 8k espinitdata_default.bin Default configuration, see note below
7E000h 8k blank.bin Filled with FFh. May be WiFi configuration
This is for ESP IoT SDK version 0.8 and above. Note that the address at which the default configuration is stored is always 16K from the end of the Flash memory. The address given in the table above is for a 512KB Flash chip.
SPI Flash ROM Layout (with OTA upgrades)
00000h 4k boot.bin Bootloader
01000h 64k app.v6.flash1.bin User application, slot 1
11000h 180k app.v6.irom0text1.bin SDK libraries, slot 1
40000h 4k Unused
41000h 64k app.v6.flash1.bin User application, slot 2
51000h 180k app.v6.irom0text1.bin SDK libraries, slot 2
7E000h 8k blank.bin Filled with FFh. May be WiFi configuration.
This is for ESP IoT SDK version 0.8 and above, supporting OTA upgrades. Note that the address at which the default configuration is stored is always 16K from the end of the Flash memory. The address given in the table above is for a 512KB Flash chip.
Exception Vectors
Address Name
40000010h DebugException
40000020h NMIException
40000030h KernelException
40000050h UserException
40000070h DoubleException
40000080h Reset
Memory-Mapped I/O Registers
Base Address Size Name Description
3FF00000h– ? dport0 3FF00014h is a clock setting register. See note 2.
60000000h 80h uart0 The UART0 config registers, see examples/IoTDemo/include/drivers/uartregister.h
60000100h 100h spi1 Unconfirmed: The SPI controller registers, see examples/IoTDemo/include/driver/spiregister.h
60000200h 100h spi0 Unconfirmed: The SPI controller registers, see examples/IoTDemo/include/driver/spiregister.h
60000300h 74h gpio Unconfirmed: The timer config registers, see include/eaglesoc.h | | 60000600h | 28h | timer | Unconfirmed: The timer config registers, see include/eaglesoc.h
60000700h A4h rtc Unconfirmed: The RTC config registers, see include/eaglesoc.h | | 60000800h | 44h | iomux | The IO MUX config registers, see include/eaglesoc.h. See note 3.
60000F00h 80h uart1
  1. Most of the memory-mapped I/O Registers live in 60000000h–60000FFFh.
  2. Setting bit 0 changes the CPU to 160 MHz mode. Clearing it means 80 MHz. Note that you need to call osupdatecpufrequency(int freqinmhz) when changing the bit. Probably to calibrate timers. The UART divisor is not updated automatically, so you also have to call uartdivmodify(uartno, clockfreqinhz / baudrateinbaud).
  3. iomux Pin Registers (60000804h–60000843h)
31    24       16        8        0
-------- -ffff--- -------- ud--UDEe
          \- Function      ||  |||\- Output Enable
                           ||  ||\- Output Enable during sleep
                           ||  |\- Pull-down during sleep
                           ||  \- Pull-up during sleep
                           |\- Pull-down
                           \- Pull-up
References
esp8266_memory_map.txt · Last modified: 2015/07/26 19:48 by dkinzer
Page Tools
