ESP8266 Support WIKI
User Tools
Site Tools
esp8266_power_usage
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Last revision Both sides next revision
esp8266_power_usage [2015/06/16 09:09]
tytower [Deep Sleep Mode]
esp8266_power_usage [2015/06/29 21:03]
tytower
Line 56: Line 56:
 </​code>​ </​code>​
-To wake itself up, the ESP8266 uses the XPD pin to trigger its reset line so those two pins need to be connected together. Wiring up XPD to DTR works. ( Note there is a small capacitor between them on Sparkfuns Thing board on the DTR line)+To wake itself up, the ESP8266 uses the XPD pin to trigger its reset line so those two pins need to be connected together. ​XPD_DCDC connects to EXT_RSTB with 0R\\
 +Wiring up XPD to DTR works. ( Note there is a small capacitor between them on Sparkfuns Thing board on the DTR line)
 ===== More data from expressif =====  ===== More data from expressif =====
-can be found at \\ [[http://​bbs.espressif.com/​download/​file.php?​id=253&​sid=398301f84155a628a3a39725226e7379|http://​bbs.espressif.com/​download/​file.php?​id=253&​sid=398301f84155a628a3a39725226e7379]]+can be found at \\ [[http://​bbs.espressif.com/​download/​file.php?​id=253&​sid=398301f84155a628a3a39725226e7379|http://​bbs.espressif.com/​download/​file.php?​id=253&​sid=398301f84155a628a3a39725226e7379]]//
 +[[http://​bbs.espressif.com/​viewtopic.php?​f=21&​t=645|http://​bbs.espressif.com/​viewtopic.php?​f=21&​t=645]]//​
 An extract from which deals with deep sleep \\ An extract from which deals with deep sleep \\
Line 84: Line 86:
 **__Note:​__** ​ \\     Init data refers esp_init_data_default.bin.\\ **__Note:​__** ​ \\     Init data refers esp_init_data_default.bin.\\
 **__Return:​__**\\ **__Return:​__**\\
- true : succeed........ ​ false : fail\\+ true : succeed........ ​ false : fail   //
esp8266_power_usage.txt · Last modified: 2016/07/05 18:38 by tumik
