esp8266_power_usage [2015/06/23 19:36] tytower [7.system_deep_sleep_set_option] |
esp8266_power_usage [2015/06/23 19:40] tytower [More data from expressif] |
Line 61: | Line 61: | ||
===== More data from expressif ===== | ===== More data from expressif ===== | ||
- | can be found at \\ [[http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379|http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379]] | + | can be found at \\ [[http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379|http://bbs.espressif.com/download/file.php?id=253&sid=398301f84155a628a3a39725226e7379]]// |
+ | [[http://bbs.espressif.com/viewtopic.php?f=21&t=645|http://bbs.espressif.com/viewtopic.php?f=21&t=645]]// | ||
- | An extract from which deals with deep sleep \\ | + | An extract from which deals with deep sleep // |
==== 6.system_deep_sleep ==== | ==== 6.system_deep_sleep ==== | ||
Line 74: | Line 75: | ||
system_deep_sleep(0): there is no wake up timer; in order to wakeup, connect a GPIO to pin RST, the chip will wake up by a falling-edge on pin RST\\ | system_deep_sleep(0): there is no wake up timer; in order to wakeup, connect a GPIO to pin RST, the chip will wake up by a falling-edge on pin RST\\ | ||
- | ==== 7.system_deep_sleep_set_option ==== | + | ==== 7.system_deep_sleep_set_option ==== |
**__Function:__** \\ Call this API before system_deep_sleep to set what the chip will do when deep-sleep wake up.\\ | **__Function:__** \\ Call this API before system_deep_sleep to set what the chip will do when deep-sleep wake up.\\ | ||
Line 85: | Line 86: | ||
**__Note:__** \\ Init data refers esp_init_data_default.bin.\\ | **__Note:__** \\ Init data refers esp_init_data_default.bin.\\ | ||
**__Return:__**\\ | **__Return:__**\\ | ||
- | true : succeed........ false : fail \\ | + | true : succeed........ false : fail // |
- | ==== And some more ==== \\ | + | **__And some more__** // |
[[http://bbs.espressif.com/viewtopic.php?f=21&t=645|http://bbs.espressif.com/viewtopic.php?f=21&t=645]] | [[http://bbs.espressif.com/viewtopic.php?f=21&t=645|http://bbs.espressif.com/viewtopic.php?f=21&t=645]] |
