Next revision | Previous revision Next revision Both sides next revision | ||
espduino [2015/01/07 13:38] tuanpm created |
espduino [2015/01/09 03:39] admin [Required] |
Line 8: | Line 8: | ||
* Support subscribing, publishing, authentication, will messages, keep alive pings and all 3 QoS levels (it should be a fully functional client). | * Support subscribing, publishing, authentication, will messages, keep alive pings and all 3 QoS levels (it should be a fully functional client). | ||
* Easy to setup and use | * Easy to setup and use | ||
+ | ====== Required ====== | ||
+ | You will need V0.2 AT+ commands from Espressif, if you do not have you can download and flash the following: ESP8266 At Command 0.2: [[https://github.com/espressif/esp8266_at|https://github.com/espressif/esp8266_at]] | ||
+ | You will also need the ESPDUINO library for Arduino that can be found here: https://github.com/tuanpmt/espduino | ||
====== Warning ====== | ====== Warning ====== |
