ESP8266 Support WIKI
User Tools
Site Tools
espduino
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
espduino [2015/01/09 01:33]
tuanpm
espduino [2015/01/09 06:28]
admin
Line 1: Line 1:
-====== ​espduino ​======+====== ​ESPDUINO ​======
- +This is MQTT client for arduino connect to broker via ESP8266 AT command, port from [[https://​github.com/​esar/​contiki-mqtt|MQTT client library for Contiki]]
-This is MQTT client for arduino connect to broker via ESP8266 AT command, port from [[MQTT client library for Contiki|https://​github.com/​esar/​contiki-mqtt]]+
 You can find the Native MQTT client library for ESP8266 work well here: [[esp_mqtt]] You can find the Native MQTT client library for ESP8266 work well here: [[esp_mqtt]]
-====== Features ​======+===== Features =====
   * Support subscribing,​ publishing, authentication,​ will messages, keep alive pings and all 3 QoS levels (it should be a fully functional client).   * Support subscribing,​ publishing, authentication,​ will messages, keep alive pings and all 3 QoS levels (it should be a fully functional client).
   * Easy to setup and use   * Easy to setup and use
-====== Required ​====== +===== Required =====
-ESP8266 At Command 0.2: [[https://​github.com/​espressif/​esp8266_at|https://​github.com/​espressif/​esp8266_at]]+You will need V0.2 AT+ commands from Espressif, if you do not have you can download and flash the following: ​ESP8266 At Command 0.2: [[https://​github.com/​espressif/​esp8266_at|https://​github.com/​espressif/​esp8266_at]]
 +You will also need the ESPDUINO library for Arduino that can be found here: https://​github.com/​tuanpmt/​espduino
-====== Warning ​======+===== Warning =====
 you have to change the SERIAL_BUFFER_SIZE minimum is 64 bytes in you have to change the SERIAL_BUFFER_SIZE minimum is 64 bytes in
Line 17: Line 18:
 C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp
 </​code>​ </​code>​
-====== Status ​======+===== Status =====
 WORKING WORKING
-====== Usage ======+===== Usage =====
 <code c> <code c>
 #include <​espduino.h>​ #include <​espduino.h>​
espduino.txt · Last modified: 2015/01/09 06:28 by admin
