Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
espduino [2015/01/09 03:39] admin [Required] |
espduino [2015/01/09 06:26] admin |
Line 1: | Line 1: | ||
====== espduino ====== | ====== espduino ====== | ||
- | + | This is MQTT client for arduino connect to broker via ESP8266 AT command, port from [[https://github.com/esar/contiki-mqtt|MQTT client library for Contiki]] | |
- | This is MQTT client for arduino connect to broker via ESP8266 AT command, port from [[MQTT client library for Contiki|https://github.com/esar/contiki-mqtt]] | + | |
You can find the Native MQTT client library for ESP8266 work well here: [[esp_mqtt]] | You can find the Native MQTT client library for ESP8266 work well here: [[esp_mqtt]] |
