Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
lua [2014/12/20 02:20] archimedespi LUA->lua |
lua [2016/02/13 12:22] terrye [NodeMCU] |
Line 1: | Line 1: | ||
====== Lua ====== | ====== Lua ====== | ||
- | There are 2 "branches:" of Lua now for ESP8266, and open source model called NodeLua and a closed source model called NodeMcu | + | There are 2 "branches:" of Lua now for ESP8266, and both are now open source. Confusingly, both use the word Node in their name -- NodeMCU and NodeLua. |
As [[http://lua.org|lua.org]] says, Lua is a powerful, fast, lightweight, embeddable scripting language. Lua combines simple procedural syntax with powerful data description constructs based on associative arrays and extensible semantics. | As [[http://lua.org|lua.org]] says, Lua is a powerful, fast, lightweight, embeddable scripting language. Lua combines simple procedural syntax with powerful data description constructs based on associative arrays and extensible semantics. | ||
- | * Lua is small: the Lua interpreter easily fits in under 100 kilobytes including the base libraries. | + | * Lua is small: the Lua interpreter easily fits in under 100 kilobytes including the base libraries. |
+ | * Lua is fast: independent benchmarks show that Lua is often amongst the fastest interpreted dynamic languages. The Lua interpreter has been extensively tuned for high performance. | ||
- | * Lua is fast: independent benchmarks show that Lua is often amongst the fastest interpreted dynamic languages. The Lua interpreter has been extensively tuned for high performance. | + | ===== NodeMCU ===== |
- | ==== Open Source NodeLua ==== | + | * [[NodeMCU]] - Initially this was closed source, but was released to open-source in October 2014. This firmware is based on the [[http://www.eluaproject.net/overview|eLua]] platform and migrated to the ESP8266 and SDK. It is under active development by esp8266 open source community. It helps you to prototype your IOT product within a few Lua script lines. |
+ | ===== NodeLua ===== | ||
+ | * This project is now moribund with the last updates in December 2014. | ||
* [[NodeLua]] - A open source firmware runs Lua code on ESP8266, written by Harold L. | * [[NodeLua]] - A open source firmware runs Lua code on ESP8266, written by Harold L. | ||
- | * [[Node WebIDE]] - A pure web-based tool works with [[NodeLua]] for Lua programming and run codes on ESP8266 over-the-air. | + | * [[NodeLua WebIDE]] - A pure web-based tool works with [[NodeLua]] for Lua programming and run codes on ESP8266 over-the-air. |
- | ==== Closed Source NodeMcu ==== | + | |
- | * [[NodeMcu]] |
