Both sides previous revision Previous revision | |||
nodelua [2015/06/06 21:47] terrye Convert to Dokuwiki markup, plus comment on last Github commit |
nodelua [2016/02/13 12:18] (current) terrye [Known issues] |
Line 15: | Line 15: | ||
* NodeLua is a Lua fork rather than an eLua fork and therefore does not use eLua's [[http://www.eluaproject.net/doc/master/en_arch_ltr.html|Lua Tiny RAM]] strategy for reducing RAM footprint, hence | * NodeLua is a Lua fork rather than an eLua fork and therefore does not use eLua's [[http://www.eluaproject.net/doc/master/en_arch_ltr.html|Lua Tiny RAM]] strategy for reducing RAM footprint, hence | ||
* The RAM size on ESP8266 is really tight for the Lua interpreter, currently there are only ~30KB free memory could be used both by NodeLua and your codes, which means dozens lines of code will used up all the heap space. | * The RAM size on ESP8266 is really tight for the Lua interpreter, currently there are only ~30KB free memory could be used both by NodeLua and your codes, which means dozens lines of code will used up all the heap space. | ||
- | * The project is now moribund, with the last GitHub commit some 6 months ago. | + | * The project is now moribund, with the last GitHub commit in December 2014. |
It's still in early alpha stage, you are welcome to be a early bird and help us to improve it! You can fork it on GitHub as well as send pull requests back. | It's still in early alpha stage, you are welcome to be a early bird and help us to improve it! You can fork it on GitHub as well as send pull requests back. |
