Both sides previous revision Previous revision | Last revision Both sides next revision | ||
nodemcu [2015/06/21 22:36] terrye [NodeMCU] fix link to correct dokuwiki format |
nodemcu [2015/12/07 18:57] mrmonteith [Connect the hardware in serial] |
Line 54: | Line 54: | ||
//Better run file.format() after flash// | //Better run file.format() after flash// | ||
- | ===== Connect the hardware in serial ===== | + | ===== Connect to the hardware via serial interface ===== |
+ | Need to explain how to connect up serial portion. | ||
baudrate:9600 | baudrate:9600 |
