Both sides previous revision Previous revision | Next revision Both sides next revision | ||
setup-linux-compiler-esp8266 [2015/06/01 09:49] tytower [Installation] |
setup-linux-compiler-esp8266 [2015/06/06 11:45] terrye Convert to Dokuwiki markup |
Line 1: | Line 1: | ||
- | ====== Linux Compiler Setups ====== | + | ====== Linux Compiler Setups ====== |
===== esp-open-sdk ===== | ===== esp-open-sdk ===== | ||
**esp-open-sdk** generates a complete toolchain to build native firmware applications. Further information can be found on its [[https://github.com/pfalcon/esp-open-sdk|GitHub Project Page]]. | **esp-open-sdk** generates a complete toolchain to build native firmware applications. Further information can be found on its [[https://github.com/pfalcon/esp-open-sdk|GitHub Project Page]]. | ||
- | ==== Installation ==== | + | ===== Installation ===== |
- | === Install dependencies === | + | ==== Install dependencies ==== |
For distributions based on Debian (e.g. Ubuntu/Mint): | For distributions based on Debian (e.g. Ubuntu/Mint): | ||
+ | <code> | ||
+ | sudo apt-get install make unrar autoconf automake libtool gcc g++ gperf flex \ | ||
+ | bison texinfo gawk ncurses-dev libexpat-dev python sed git | ||
+ | </code> | ||
+ | :!: add ''libtool-bin'' if using Debian8/Jessie. | ||
- | sudo apt-get install make unrar autoconf automake libtool gcc g++ gperf \ | + | ==== Build toolchain ==== |
- | flex bison texinfo gawk ncurses-dev libexpat-dev python sed git | + | <code> |
+ | git clone https://github.com/pfalcon/esp-open-sdk.git | ||
+ | cd esp-open-sdk | ||
+ | make STANDALONE=y | ||
+ | </code> | ||
- | :!: add libtool-bin if using Debian8/Jessie. | + | Note: If you set ''STANDALONE=y'', then the current Espressif SDK will be directly integrated into your toolchain. This eases the development, but makes it difficult to upgrade SDK versions later on. Set ''STANDALONE=n'' if you want to separate the SDK. |
- | === Build toolchain === | + | ==== Configure PATH ==== |
- | git clone https://github.com/pfalcon/esp-open-sdk.git | + | |
- | cd esp-open-sdk | + | |
- | make STANDALONE=y | + | |
- | Note: If you set ''STANDALONE=y'', the current Espressif SDK will be directly integrated into your toolchain. This eases the development, but makes it difficult to upgrade SDK versions later on. Set ''STANDALONE=n'' if you want to separate the SDK. | + | |
- | === Configure PATH === | + | |
To call the generated ''xtensa-lx106-*'' binaries, you have to add the toolchain to your ''PATH''. | To call the generated ''xtensa-lx106-*'' binaries, you have to add the toolchain to your ''PATH''. | ||
You can set ''PATH'' on every new terminal session: | You can set ''PATH'' on every new terminal session: | ||
- | export PATH=[your esp-open-sdk directory]/bin:$PATH | + | <code> |
+ | export PATH=[your esp-open-sdk directory]/bin:$PATH | ||
+ | </code> | ||
To make this change permanent add the above line to your ''.profile'' file in your home directory. | To make this change permanent add the above line to your ''.profile'' file in your home directory. | ||
- | _________________________________________________________________________________________________ | + | |
- | __=====**Installation of Arduino IDE on most Linux Distros** =====__: | + | |
- | Make sure you have javaJRE installed first: | + | |
- | Go to Arduino.cc : | + | |
- | Download Latest IDE for Linux: | + | |
- | Extract it wherever you want it: | + | |
- | Go into that directory and open a terminal : | + | |
- | type " ./Arduino ": | + | ===== Installation of Arduino IDE on most Linux Distros ===== |
- | Thats it . You can drag that shell script to the desktop if you wish. | + | * Make sure you have javaJRE installed first. |
+ | * Go to ''Arduino.cc'' and download Latest IDE for Linux. | ||
+ | * Extract it wherever you want it. | ||
+ | * Go into that directory and open a terminal and type ''./Arduino'' | ||
- | Now you follow the instructions on ESP8266/Arduino to add the ESP8266 library | + | Thats it . You can drag that shell script to the desktop if you wish. Now you follow the instructions on ESP8266/Arduino to add the ESP8266 library |
