ESP8266 Support WIKI
User Tools
Site Tools
Command disabled: login
setup-linux-compiler-esp8266
Table of Contents
Linux Compiler Setups
esp-open-sdk
esp-open-sdk generates a complete toolchain to build native firmware applications. Further information can be found on its GitHub Project Page.
Installation
Install dependencies
For distributions based on Debian (e.g. Ubuntu/Mint):
sudo apt-get install make unrar autoconf automake libtool gcc g++ gperf flex \
                     bison texinfo gawk ncurses-dev libexpat-dev python sed git
:!: add libtool-bin if using Debian8/Jessie.
Build toolchain
git clone https://github.com/pfalcon/esp-open-sdk.git
cd esp-open-sdk
make STANDALONE=y
Note: If you set STANDALONE=y, then the current Espressif SDK will be directly integrated into your toolchain. This eases the development, but makes it difficult to upgrade SDK versions later on. Set STANDALONE=n if you want to separate the SDK.
Configure PATH
To call the generated xtensa-lx106-* binaries, you have to add the toolchain to your PATH. You can set PATH on every new terminal session:
export PATH=[your esp-open-sdk directory]/bin:$PATH
To make this change permanent add the above line to your .profile file in your home directory.
Installation of Arduino IDE on most Linux Distros
  • Make sure you have javaJRE installed first.
  • Go to Arduino.cc and download Latest IDE for Linux.
  • Extract it wherever you want it.
  • Go into that directory and open a terminal and type ./Arduino
Thats it . You can drag that shell script to the desktop if you wish. Now you follow the instructions on ESP8266/Arduino to add the ESP8266 library
Also see Tool chain: using the Arduino IDE.
setup-linux-compiler-esp8266.txt · Last modified: 2015/06/18 00:41 by terrye
Page Tools
