Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
setup-osx-compiler-esp8266 [2015/02/11 17:12] nfriedly |
setup-osx-compiler-esp8266 [2017/03/13 21:56] polarstate [Dependencies] |
Line 7: | Line 7: | ||
hdiutil create ~/Desktop/eos.dmg -volname "esp-open-sdk" -size 10g -fs "Case-sensitive HFS+" | hdiutil create ~/Desktop/eos.dmg -volname "esp-open-sdk" -size 10g -fs "Case-sensitive HFS+" | ||
hdiutil mount ~/Desktop/eos.dmg | hdiutil mount ~/Desktop/eos.dmg | ||
- | cd /Volumes/eos-open-sdk | + | cd /Volumes/esp-open-sdk |
===== esp-open-sdk with Brew ===== | ===== esp-open-sdk with Brew ===== | ||
Line 18: | Line 18: | ||
brew install grep | brew install grep | ||
brew install autoconf | brew install autoconf | ||
- | brew install binutils (for gobjcopy) | + | brew install binutils |
- | brew install gawk (required overwriting the non-gnu awk in my case) | + | brew install gawk |
- | brew install autoconf | + | brew install wget |
+ | brew install automake | ||
+ | brew install libtool | ||
+ | brew install help2man | ||
+ | binutils is needed for gobjcopy | ||
+ | gawk is required for overwriting the non-gnu awk in my case | ||
If you get the error "configure: error: could not find GNU awk", run | If you get the error "configure: error: could not find GNU awk", run | ||
Line 30: | Line 37: | ||
==== Dependencies ==== | ==== Dependencies ==== | ||
- | sudo port install gsed gawk binutils gperf grep gettext py-serial | + | sudo port install gsed gawk binutils gperf grep gettext py-serial wget |
==== Get the compiler ==== | ==== Get the compiler ==== |
