setup-osx-compiler-esp8266 [2015/08/19 16:41] jseb [Dependencies] |
setup-osx-compiler-esp8266 [2017/03/13 22:41] (current) polarstate [Dependencies] |
Line 18: | Line 18: | ||
brew install grep | brew install grep | ||
brew install autoconf | brew install autoconf | ||
- | brew install binutils (for gobjcopy) | + | brew install binutils |
- | brew install gawk (required overwriting the non-gnu awk in my case) | + | brew install gawk |
- | brew install autoconf | + | |
brew install wget | brew install wget | ||
brew install automake | brew install automake | ||
brew install libtool | brew install libtool | ||
+ | brew install help2man | ||
+ | binutils is needed for gobjcopy | ||
+ | gawk is required for overwriting the non-gnu awk in my case | ||
If you get the error "configure: error: could not find GNU awk", run | If you get the error "configure: error: could not find GNU awk", run | ||
Line 29: | Line 33: | ||
brew link --overwrite gawk | brew link --overwrite gawk | ||
+ | If you get the error "./zconf.hash.c:167:1: error: conflicting types for 'kconf_id_lookup'" | ||
+ | brew uninstall gperf | ||
+ | see: https://github.com/pfalcon/esp-open-sdk/issues/236 for reference | ||
===== esp-open-sdk with MacPorts ===== | ===== esp-open-sdk with MacPorts ===== | ||
