Both sides previous revision Previous revision | |||
setup-windows-compiler-esp8266 [2018/02/25 03:56] dcm684 [Toolset installation] Escaped out underscores in paths |
setup-windows-compiler-esp8266 [2018/02/25 04:12] (current) dcm684 [Things to watch out for] Escaped underscore |
Line 59: | Line 59: | ||
By default, all code goes into iram, which is only 32k, so it is easy to overflow that segment by linking in a bunch of stuff from the libraries or from your own code. | By default, all code goes into iram, which is only 32k, so it is easy to overflow that segment by linking in a bunch of stuff from the libraries or from your own code. | ||
- | Use **ICACHE_FLASH_ATTR** on your functions to make sure they go into irom instead. Irom resides off-chip on a 4M flash ROM, thus leaving about 240-440kB for applications. Although the final compiled program appears huge (about 180k in irom, and 28k in iram), most of this is library code that runs the Wifi and IP stacks. The actual user application is something like 8k. | + | Use **ICACHE\_FLASH\_ATTR** on your functions to make sure they go into irom instead. Irom resides off-chip on a 4M flash ROM, thus leaving about 240-440kB for applications. Although the final compiled program appears huge (about 180k in irom, and 28k in iram), most of this is library code that runs the Wifi and IP stacks. The actual user application is something like 8k. |
The hardware design shown above also assumes that the switch will remain open at bootup, as GPIO2 needs to be high for the chip to boot normally. | The hardware design shown above also assumes that the switch will remain open at bootup, as GPIO2 needs to be high for the chip to boot normally. |
