Both sides previous revision Previous revision | Next revision Both sides next revision | ||
setup-windows-compiler-esp8266 [2018/02/17 19:19] dcm684 Made Arduino header same level as VS and Eclipse |
setup-windows-compiler-esp8266 [2018/02/17 19:49] dcm684 Emphasized prebuilt download |
Line 13: | Line 13: | ||
This particular version of the toolset is designed to work under Windows 7 or 8, 32 or 64bit. | This particular version of the toolset is designed to work under Windows 7 or 8, 32 or 64bit. | ||
- | You can download a pre-built ESP8266 toolchain that contains Python and the ESP8266 SDK [[http://gnutoolchains.com/esp8266/|here]]. Alternatively you can gather the necessary components manually: | + | You can **[[http://gnutoolchains.com/esp8266/|download]]** a pre-built ESP8266 toolchain that contains Python and the ESP8266 SDK. Alternatively you can gather the necessary components manually: |
* Create a directory to put all your ESP stuff in. I put mine in **E:\ESP8266**, but obviously yours will be different. | * Create a directory to put all your ESP stuff in. I put mine in **E:\ESP8266**, but obviously yours will be different. |
