some_links [2015/07/11 20:46] tytower |
some_links [2015/08/02 21:12] tytower |
Line 1: | Line 1: | ||
===Some links:=== | ===Some links:=== | ||
+ | ESP8266/Arduino Read-Me http://arduino.esp8266.com/versions/1.6.5-988-gfd1d9da/doc/reference.html | ||
Hackaday In depth look at chip [[http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/#more-148943|http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/#more-148943]] \\ | Hackaday In depth look at chip [[http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/#more-148943|http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/#more-148943]] \\ | ||
Specifications, schematics: http://www.mikrocontroller.net/attachment/231858/0A-ESP8266_Specifications_v4.pdf \\ | Specifications, schematics: http://www.mikrocontroller.net/attachment/231858/0A-ESP8266_Specifications_v4.pdf \\ | ||
Line 18: | Line 20: | ||
Interfacing with Teensy http://kaspars.net/blog/electronics/esp8266-teensy-arduino | Interfacing with Teensy http://kaspars.net/blog/electronics/esp8266-teensy-arduino | ||
- | :?: @tytower: http://www.esp8266.com/wiki/doku.php?id=wiki:syntax#tables | ||
- | Maybe a table is easier to manage? | ||
- | Just kill it if you don't like it... | ||
- | ^ URL ^ Description ^ Date added ^ Date verified ^ | ||
- | | [[http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/#more-148943]] | todo:description | 20150710 | todo:check link | | ||
- | | [[http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/#more-148943]] | Hackaday In depth look at chip | 20150710 | todo:check link | | ||
- | | http://www.mikrocontroller.net/attachment/231858/0A-ESP8266_Specifications_v4.pdf | Wi07c - ElectroDragon - Specifications, schematics | 20150710 |todo:check link | |
