ESP8266 Support WIKI
User Tools
Site Tools
start
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Last revision Both sides next revision
start [2016/07/04 01:34]
tkraspi [ESP8266.com Users Projects]
start [2020/07/02 13:21]
angeleena
Line 15: Line 15:
 Please visit [[http://​www.esp8266.com|The ESP8266 Community Forum]] to chat with others about this wonderful IC! Please visit [[http://​www.esp8266.com|The ESP8266 Community Forum]] to chat with others about this wonderful IC!
 +You can also visit [[http://​www.everythingESP.com|EverythingESP.com]] where you will find tutorials, news, and projects for the ESP8266 and ESP32. Once you aquire a login for this site, you can submit your projects, tutorials, or news immediately.
 +There are some more imp resource Documentation for reference:
 +  - [[http://​www.electronicwings.com/​nodemcu/​basics|NodeMCU Introduction]]
 +  - [[http://​www.electronicwings.com/​nodemcu/​esplorer-ide|NodeMCU ESplorer IDE]]
 +  - [[http://​www.electronicwings.com/​nodemcu/​arduino-ide|NodeMCU Arduino IDE]]
 +  - [[http://​www.electronicwings.com/​nodemcu/​interface|NodeMCU Sensors, Modules Interfacing example]]
 ===== Table of Contents ===== ===== Table of Contents =====
Line 25: Line 33:
 ==== Device Overview ==== ==== Device Overview ====
-  * {{:​0A-ESP8266__Datasheet__EN_v4.3.pdf|New English Espressif June 2015 ESP8266 ​Datasheet PDF}} +  * [[Download Datasheets for ESP8266]]
-  * {{:​esp8266_specifications_english.pdf|Original Espressif October 2013 ESP8266 Datasheet PDF}}+
   * [[Feature Set]]   * [[Feature Set]]
   * [[Device architecture]]   * [[Device architecture]]
Line 36: Line 43:
   * [[ESP8266 Memory Map]]   * [[ESP8266 Memory Map]]
   * [[ESP8266 Power Usage]]   * [[ESP8266 Power Usage]]
 +  * [[ESP8266 Interrupts]]
 ==== ESP8266 On-Chip development ==== ==== ESP8266 On-Chip development ====
   * [[Toolchain]]   * [[Toolchain]]
 +  * [[Connecting The Board]]
   * [[Loading Firmware]]   * [[Loading Firmware]]
   * [[Hardware SPI Information]]   * [[Hardware SPI Information]]
   * [[Mode Changes]]   * [[Mode Changes]]
 ==== ESP8266 Compiler Setup and Usage ==== ==== ESP8266 Compiler Setup and Usage ====
-  * [[Windows setup-windows-compiler-esp8266|Visual Studio IDE]]+  * [[Windows ​setup-windows-compiler-esp8266|Arduino IDE]]
 +  * [[setup-windows-compiler-esp8266|Visual Studio IDE]]
   * [[setup-OSX-compiler-esp8266|OSX]]   * [[setup-OSX-compiler-esp8266|OSX]]
Line 51: Line 62:
 ==== Getting Started ==== ==== Getting Started ====
-  * [[getting-started-with-the-esp8266|ESP8266 101]] +  ​* [[start-with-esp-12-arduino|Start with the ESP8266-12E and the Arduino tools]]
-  * [[start-with-esp-12-arduino|Start ​with the ESP-1 and the Arduino tools]]+  ​* [[getting-started-with-the-esp8266|ESP8266 101]] older low level version
 +  * [[getting-started-with-the-NodeMCU development board|NodeMCU development board]]
   * [[ota-over-the-air-esp8266|Over the Air information (OTA)]]   * [[ota-over-the-air-esp8266|Over the Air information (OTA)]]
Line 59: Line 71:
   * [[ESP8266Basic]]   * [[ESP8266Basic]]
   * [[Espruino JavaScript]]   * [[Espruino JavaScript]]
 +  * [[https://​www.zerynth.com/​blog/​python-for-esp8266-in-just-a-few-clicks-using-zerynth/​|Zerynth - Python for ESP8266]]
 ==== Integrations ==== ==== Integrations ====
   * [[raspberrypi-Integration-with-esp8266|Raspberry Pi & ESP8266]]   * [[raspberrypi-Integration-with-esp8266|Raspberry Pi & ESP8266]]
Line 78: Line 90:
   * [[https://​www.supla.org|SUPLA]] - Open Source building automation system based on ESP8266   * [[https://​www.supla.org|SUPLA]] - Open Source building automation system based on ESP8266
   * [[https://​github.com/​SUPLA/​ESP8266|SUPLA - Firmware]] - WiFi-Socket firmware and Gate-Module firmware based on SUPLA project   * [[https://​github.com/​SUPLA/​ESP8266|SUPLA - Firmware]] - WiFi-Socket firmware and Gate-Module firmware based on SUPLA project
 +  * [[https://​www.zerynth.com/​blog/​how-to-program-nodemcu-esp8266-in-python-with-zerynth/​|Getting Started with Python for ESP8266 using Zerynth]]
 +  * [[https://​www.allaboutcircuits.com/​projects/​make-a-web-server-with-esp8266/​]] - Make a Web Server with ESP8266
 +  * [[https://​github.com/​arendst/​Sonoff-Tasmota]] - Provides ESP8266-based Sonoff-Tasmota firmware for iTead Sonoff, Wemos and NodeMCU hardware with Web, MQTT and OTA firmware using Arduino IDE or PlatformIO - See http://​thehackbox.org/​tasmota/​ for more info on Sonoff-Tasmota
 +  * [[https://​github.com/​xoseperez/​espurna]] - Home automation firmware for ESP8266-based devices - See http://​tinkerman.cat for more info on ESPurna
 +  * [[https://​github.com/​letscontrolit/​ESPEasy]] - The ESP Easy firmware can be used to turn the ESP module into an easy multifunction sensor device for Home Automation solutions - See https://​www.letscontrolit.com/​wiki/​index.php/​ESPEasy for more info on ESPEasy
 +  * [[http://​www.andreadrian.de/​ESP_Schachzwerg/​index.html]] - A chess playing computer with touchscreen LCD user interface.
 +https://​www.fieldengineer.com/​skills/​cisco-certified-design-associate
start.txt · Last modified: 2020/07/11 20:58 by admin
