start [2018/03/23 18:39] jpascher [Getting Started] |
start [2019/03/27 03:08] megahurtz [ESP8266.com Users Projects] - Added 3 ESP8266 projects detailed and reviewed here: https://lobradov.github.io/FOSS-Firmware-comparison-overview/ |
Line 17: | Line 17: | ||
You can also visit [[http://www.everythingESP.com|EverythingESP.com]] where you will find tutorials, news, and projects for the ESP8266 and ESP32. Once you aquire a login for this site, you can submit your projects, tutorials, or news immediately. | You can also visit [[http://www.everythingESP.com|EverythingESP.com]] where you will find tutorials, news, and projects for the ESP8266 and ESP32. Once you aquire a login for this site, you can submit your projects, tutorials, or news immediately. | ||
+ | There are some more imp resource Documentation for reference: | ||
+ | - [[http://www.electronicwings.com/nodemcu/basics|NodeMCU Introduction]] | ||
+ | - [[http://www.electronicwings.com/nodemcu/esplorer-ide|NodeMCU ESplorer IDE]] | ||
+ | - [[http://www.electronicwings.com/nodemcu/arduino-ide|NodeMCU Arduino IDE]] | ||
+ | - [[http://www.electronicwings.com/nodemcu/interface|NodeMCU Sensors, Modules Interfacing example]] | ||
===== Table of Contents ===== | ===== Table of Contents ===== | ||
Line 56: | Line 62: | ||
==== Getting Started ==== | ==== Getting Started ==== | ||
- | * [[start-with-esp-12-arduino|Start with the ESP-12E and the Arduino tools]] | + | * [[start-with-esp-12-arduino|Start with the ESP8266-12E and the Arduino tools]] |
* [[getting-started-with-the-esp8266|ESP8266 101]] older low level version | * [[getting-started-with-the-esp8266|ESP8266 101]] older low level version | ||
* [[getting-started-with-the-NodeMCU development board|NodeMCU development board]] | * [[getting-started-with-the-NodeMCU development board|NodeMCU development board]] | ||
Line 85: | Line 91: | ||
* [[https://github.com/SUPLA/ESP8266|SUPLA - Firmware]] - WiFi-Socket firmware and Gate-Module firmware based on SUPLA project | * [[https://github.com/SUPLA/ESP8266|SUPLA - Firmware]] - WiFi-Socket firmware and Gate-Module firmware based on SUPLA project | ||
* [[https://www.zerynth.com/blog/how-to-program-nodemcu-esp8266-in-python-with-zerynth/|Getting Started with Python for ESP8266 using Zerynth]] | * [[https://www.zerynth.com/blog/how-to-program-nodemcu-esp8266-in-python-with-zerynth/|Getting Started with Python for ESP8266 using Zerynth]] | ||
+ | * [[https://www.allaboutcircuits.com/projects/make-a-web-server-with-esp8266/]] - Make a Web Server with ESP8266 | ||
+ | * [[https://github.com/arendst/Sonoff-Tasmota]] - Provides ESP8266-based Sonoff-Tasmota firmware for iTead Sonoff, Wemos and NodeMCU hardware with Web, MQTT and OTA firmware using Arduino IDE or PlatformIO - See http://thehackbox.org/tasmota/ for more info on Sonoff-Tasmota | ||
+ | * [[https://github.com/xoseperez/espurna]] - Home automation firmware for ESP8266-based devices - See http://tinkerman.cat for more info on ESPurna | ||
+ | * [[https://github.com/xoseperez/espurna]] - The ESP Easy firmware can be used to turn the ESP module into an easy multifunction sensor device for Home Automation solutions - See https://www.letscontrolit.com/wiki/index.php/ESPEasy for more info on ESPEasy | ||
