toolchain [2016/01/12 18:46] flaming_goat fixed link to raspberry pi 2 |
toolchain [2016/05/22 13:57] admin old revision restored |
Line 85: | Line 85: | ||
for m in lua-bitlib luafilesystem md5 luaposix luasocket; do sudo luarocks install $m; done | for m in lua-bitlib luafilesystem md5 luaposix luasocket; do sudo luarocks install $m; done | ||
- | and now you are good to go. | + | and now you are good to go. If you want to work on the nodeMCU firmware documentation then you will also need the MkDocs toolkit: |
+ | sudo apt-get install python-pip | ||
+ | sudo pip install mkdocs | ||
+ | See the [[http://www.mkdocs.org/|MkDocs Website]] for more info. | ||
=====Using the Arduino IDE.===== | =====Using the Arduino IDE.===== | ||
